Wanting to buy new tractor
/ Wanting to buy new tractor #22
/ Wanting to buy new tractor #23
If you can find A Yanmar dealer anywhere close sounds like the YT359 would be perfect and you will really like the IHMT tranny, I traded my Case 45C in on this and it has twice the power and I have the YT347 which has a little smaller engine but it is a great tractor with a ten year warranty at a reasonable price. Good luck.
/ Wanting to buy new tractor #24
On our tractor you can see all four tires no
problem to see anything and the mirrors you
can see very good behind you and you can
see the 3 pt hitch and the linkage
willy
/ Wanting to buy new tractor #25
Do you use the clutch when shifting? Andy at Yanmar says I should; everyone else, including my dealer and many other dealers on YouTube and Yanmar's website, says clutchless.
/ Wanting to buy new tractor #26
you can use it but it isn't required but it does make it easy to shift the range lever and if you want to ease into a tight spot but for normal use it is like a forklift or back hoe just shift into forward or reverse and it works really well.
Thanks for all of the replies. I have been impressed with the Yanmar. I haven't seen one or know of any dealers, but I do know they have good engines and make tractors with brands other than Yanmar.
/ Wanting to buy new tractor #28
I picked up a Yanmar ym342 a few months ago. It's been fantastic. I do some bucket work. Clutching has been a non issue. Zero inconvenience. And, the heavier frame, lift capacity is great.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
The Owner Corporation 3314 (A60463)
The Owner...
2022 Kubota MX5400 (A60462)
2022 Kubota MX5400...
CFG QK20R (A60463)
CFG QK20R (A60463)
New Holland 3930 (A60462)
New Holland 3930...
2004 Ford E-450 Super Duty Van, VIN # 1FDXE45S44HB15933 (A61569)
2004 Ford E-450...
