Anyone try the Holzfforma Fuel/oil container?
   / Anyone try the Holzfforma Fuel/oil container? #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Unfortunately, my much liked Husqvarna fuel & oil refueling container broke. The auto shut off feature for the fuel side stays stuck open.
I really like this container and have used the heck out of it.
Bought it for like $40 in 2019.
Now they are $150.
I see there are replacement nozzles for other types, but haven’t found for Husq.
Found this
   / Anyone try the Holzfforma Fuel/oil container? #2
I buy two stroke oil in six packs with each bottle just right for my 2 gal plastic gas can. When I run out, one unit of oil is poured in as I load the jug in the truck to fill ALL the gas cans at the station.
Can't get much easier.
   / Anyone try the Holzfforma Fuel/oil container? #4
I found one on Ebay... for $47. The Holzforma looks kinda weird and with how well the Husky works I'd be tempted to choke up on the credit card and buy the replacement spout.
   / Anyone try the Holzfforma Fuel/oil container? #5
I don't saw much (anymore) so I buy 40:1 & 50:1 premix by the gallon and decant onto smaller cans it comes in to take to the job. (Workers usually bring their own saws & mix. Fine with me. :) )
Those quart cans are also nice with other mixes for older ratios (30:1, others, re-labelled) and they don't need to be vented, so a mix remains fresh for years. I usually get two or more fills from a quart, but depending on the saw/tool that could be over two or more seasons. (12", 14", 2x18", 20" saws)
   / Anyone try the Holzfforma Fuel/oil container? #6
   / Anyone try the Holzfforma Fuel/oil container? #7
A gallon a day, off the pile, is all these old bones can take... I saw in intervals "by the tank".
   / Anyone try the Holzfforma Fuel/oil container? #8
I add Sta-Bil to each gas can when I bring 'em home. Might go into the bucket truck, Mini-BH, chipper, tiller, golf cart, generator, ZTR, or get mixed for a trimmer, saw, or PHD but I never know where or when I'll pour it.
   / Anyone try the Holzfforma Fuel/oil container? #9
uh, you oughta try one of these Husqvarna cans for chain sawing
yes, it is much easier.
Why so much oil? 1/2 as much as fuel? why carry oil that you will not use until you refill the fuel.
A solution to a problem no one has?
   / Anyone try the Holzfforma Fuel/oil container? #10
I tired of messing with 2-cycle gas and pull-start stuff, now I have Ryobi 40V electric string trimmer and chain saw.
By the time the 4AH battery runs down so am I, so we go to the house for R&R.
I do have a 6AH and 2AH battery in the garage in case I feel feisty and want to cut more.
   / Anyone try the Holzfforma Fuel/oil container? #11
You must not heat with wood! ;-)
   / Anyone try the Holzfforma Fuel/oil container? #12
I'm not able @ 82, but if I still was I'd carry spare batteries instead of 2-cycle gas.
Years ago my BIL and I would cut wood for us and my dad. We normally stopped cutting and splitting after 20 cords of wood.
BTW, virtually all small engines state in the owners manual to only use premium gas, without Ethanol. That's $5/G around me.
   / Anyone try the Holzfforma Fuel/oil container? #13
Bar oil and premix
   / Anyone try the Holzfforma Fuel/oil container? #14
BTW, virutally all small engines state in the owners manual to only use premium gas, without Ethanol. That's $5/G around me.
That's just STUPID advice.
The effective compression ratio of modern two strokes is no better than 8 or 9 to one. High Octane is just so much fluey!
Ethanol is a carburettor component issue. I've had good luck, but I'm not opposed to taking a carb apart to unstick the sticky parts.
I'm 73, and "able" is no reason to buy a fuel can with stupid features.
   / Anyone try the Holzfforma Fuel/oil container? #15
Bar oil and premix
A can for the guy in the woods,
Not a guy with a Husky....
I see it now.
I do have a length of masons line fixed to my fuel can that I use to tie on a bottle of bar oil when I'm away from the yard. A "constrictor knot" around the bottle neck works fine!
  • Good Post
Reactions: D&D
Its bar oil for chainsaws, not 2 cycle oil.
   / Anyone try the Holzfforma Fuel/oil container? #17
Same here, no chance of screwing up the ratio.
The Echo oil is supposed to have stabilizer in it
   / Anyone try the Holzfforma Fuel/oil container? #18
HD I have one that looks like this.
But I got it probably 30+ years ago, pre nozzle foolishness I believe from Baileys.com.
Anymore I find it a little more convenient to just carry a small jug of mix and whatever jug the bar oil comes in.
I really like the Husky set up. 2 reservoirs in one can. Auto shut off nozzles, so no spillage, and tool storage.
I think they used to sell them in Europe only, but there was a way to get them pretty cheap.
Mine was only $40 on Amazon 5yr ago, now $150???? 350% inflation?
   / Anyone try the Holzfforma Fuel/oil container? #20
You can just pull the spring out and use it as a normal pouring mix container without the push in and release spring.
I always just use regular spout on bar oil never the auto spring loaded one.
Some swell up due to folks using E-gas and had to do that fix.
I have one and only use Efree so never a issue yet unless it was like 100F out then would get sticky. Otherwise I would just pull spring out myself.
Back in 2018 was 28 and shipping from UK.
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
