Best lubricant i have found.
/ Best lubricant i have found. #1
Tchamp
Baldwin Georgia
Power trac PT-2422
I’ve searched many times for a good lubricant for the ball joints on the end of the hydraulic rams on the power tracks and I found this one by accident, but it works the best out of everything I’ve ever used. I wanted to pass it along so anybody else could try it and let me know what they think
it is on Amazon and worth every penny.
/ Best lubricant i have found. #2
Just curious, did you find anything negative using the lube that PT recommends at 8 hour intervals?
/ Best lubricant i have found. #3
I’ve searched many times for a good lubricant for the ball joints on the end of the hydraulic rams on the power tracks and I found this one by accident, but it works the best out of everything I’ve ever used. I wanted to pass it along so anybody else could try it and let me know what they thinkView attachment 1786637 it is on Amazon and worth every penny.
I have found quite a few better lubricants, depending on where it's being applied. But that one may be particularly good for the ball linkages on our PTs
/ Best lubricant i have found. #4
When you say it "may be" better, doesn't that mean it may not be better too?
The "few better lubricants" that you found, what did you find about them that makes them better?
What did you find with the factory specified lubricant that makes it not as good (as the new lubes you found)?
/ Best lubricant i have found. #6
Please describe this ball lubricant better. Why is it better for your hitch?
Your in the wrong forum. Look up ball lube and go there.
/ Best lubricant i have found. #9
I may not have been thinking only about about mobile equipment.
Please describe why this ball lubricant is better. Why is it better for your hitch?
It stays on longer and is extremely tacky, works well lubricating
Used Landpride GR1525 Stump Grinder
Used Landpride...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2025 Pabreak 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
