Mixing concrete - "Mud mixer" alternative. Steele mixer
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #72
I have the harbor freight mixer and over 1000 bags through it. I busted up all the concrete around my pool and poured all new. I also poured a generator slab that's 6'x8'. It has done the job and then some.
The easiest way is to have 2 people. One on water and one on concrete bags. Get a bucket and mark a line for ~1.5g of water per 80lb bag. One person fills water to that line every time. Pour water in, put bag on top of mixer, cut, flip bag, dump, 2 minutes mixing, pour, repeat. I got it to 3-5min per bag. I'd move bags, mix, pour, the other person would just fill water bucket, and dump.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #73
I bought an old electric mixer at a garage sale 3 years ago.
They wanted $50 for it. I offered $5 if they loaded in into my truck. They took the deal.
I have been lucky, I only mixed two 60# bags of concrete.
Plus about 8 gallons of black walnuts.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #74
Have a barrel filling constantly (or a half barrwl), and dipping an appropriate sized bucket is Far faster than hose filling each bucket
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #75
I believe the dry mix they are discussing is the trend on YouTube of guys dumping quikcrete straight from the bags into form boards without mixing, and then soaking the surface with water to start the hydration process; not high early as used in concrete roadway repairs.
That could well be true.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #76
Assembly line efficiency (y)
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #77
The only thing I'd change on it is larger tires for easier rolling. Even with that, I was able to roll up and mix right over each footing. No shoveling required.
Tractor to lift the bags is pretty handy....
TANK MANIFOLD (A58214)
PALLET TOE OF MISC PARTS (A58374)
PALLET TOE OF MISC...
EZ-GO GOLF CART (A56859)
EZ-GO GOLF CART...
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
