Mixing concrete - "Mud mixer" alternative. Steele mixer
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #51
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #52
I had a mason do a block wall for us and I wanted it filled with concrete.
He mixed the concrete in his mortar mixer.
Why aren’t they for both applicable for mortar and concrete?
I did the same thing with my harbor freight concert mixer. Used it for concrete for the footings, mortar for the block wall, then concrete to fill the blocks. Small batches make no difference which machine you use.
But I'll tell you, you'd better clean them out after each use or you'll be sorry. ;)
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #53
Portland Cement is a glue. It is what holds the sand and rock together. Every piece of sand and rock needs to be coated with Portland Cement to function Water creates a chemical reaction, kind of like a two part epoxy, that converts Portland Cement into glue.
The water actually changes into something else when mixed with the Portland Cement. Excess water evaporates, and when too much water is used, you lose volume of the concrete, which results in cracking. Rebar holds it all together to minimize cracking and add strength.
If you do not mix the Portland Cement with everything else, you will never get the proper amount of water to mix with the Portland Cement, and it will not coat the sand and rock thoroughly. It will get hard, but it will achieve it's maximum strength. Not even close.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #54
Concrete is an engineered material. There are numerous hand books on use and design that are very precise. Fortunately it is an accommodating product that for much common use ( homeowner ) serves well despite abnormalities from proper design.
Dry mix, some places known as high early, is used in a lot of different type situations.
Concrete blocks and such items use a high early concrete mix.
Portland Cement should have handbooks on design and pouring.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #55
I believe the dry mix they are discussing is the trend on YouTube of guys dumping quikcrete straight from the bags into form boards without mixing, and then soaking the surface with water to start the hydration process; not high early as used in concrete roadway repairs.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #56
Sorry I didn't read all of the posts in this thread.
But coming from someone that just poured a 32 bag slab this past sunday. A 50 bag slab would be absolutely no fun!! You would need at least 1 other strong backed individual or better yet 2 helpers to make this anything less than absolutely miserable. Using a mixer like in your original post would make it even more painful. Me and a strong, young friend were able to do the 32 bags in about 2.5 hours using an electric mixer that you can put 3 80# bags in. We got a system down and if flowed well. I am pleased with the results. I would not wanted to have done much more.
We did forty 80lb bags in a hour with the mud mixer.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #59
I’ve watched a few videos of it, but they were all on tiny jobs. Was 40 sacks the total, or was that your hourly rate?
My biggest issue with it is the price. But I’m also unsure if it’s any better then the Imer Cement Mixer that I already have
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #60
Pretty hard to beat an electric motor mixer for saving labor and thoroughly mixing the concrete. It didn't take too many bags of hand mixing concrete to convince me to buy an electric mixer.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
Doyle Fertilizer Spreader (A56435)
Doyle Fertilizer...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2017 John Deere 5090GN (A53317)
2017 John Deere...
