Rotary Cutter Gear box repair/replace?
/ Rotary Cutter Gear box repair/replace? #1
Billcurley63
Case 485 1987
Does anyone have a clue as to what brand this gearbox may be or what I need to know to replace and or repair it? My best guess is that it is the same make and model year as the tractor, Case 1987 but I can not find any markings on it anywhere other than what appears to be a 23 on the side of the gearbox near the input.
/ Rotary Cutter Gear box repair/replace? #2
Welcome to TBN!
Probably a Bushhog 406. What's wrong with it?
I haven’t pulled anything off as of yet to investigate but the shaft just spins and blades do not. It came with the tractor I just bought and the previous owner didn’t know either
/ Rotary Cutter Gear box repair/replace? #4
When you open the gearbox, you should find some part numbers stamped on the gears. That should determine who made the box
Thank you, hopefully I won’t be asking stupid questions again for a while. ;-)
/ Rotary Cutter Gear box repair/replace? #6
We love stupid questions. It makes us stupider look brilliant. 🤣
/ Rotary Cutter Gear box repair/replace? #7
Depending on what you find when you get into the gearbox/parts availability/etc., Surplus Center sells complete gearboxes for rotary cutters
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2018 New Holland C227 Compact Track Loader (A61307)
2018 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pick up Bed (A60352)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
