For those with block heaters
/ For those with block heaters #141
Before this thread devolves into a scholastic debate over the intercept of two scales:
/ For those with block heaters #142
I've experienced MAJOR frustration due to extreme cold weather. Get up @ 1am so I can clear the snow off my mile long gravel driveway and get to work on time. Leave for work @ 5am and fight the uncleared county roads. All the way to work. Then...I'm the ONLY fool who shows up for work. Due to heavy snows and cold weather - work has been cancelled for that day.
It always really irritated me, when I'd manage to get my long drive cleared and drive an hour to work, just to find people who lived in town, 5 minutes from the office, somehow couldn't get their lazy asses to work. Some folks will use any excuse they can find, to avoid a little work.
/ For those with block heaters #143
At -40 I would only start my tractor if I absolutely have too, I would put my magnetic block heather on for 2 hours prior and turn on the antifreeze heater for 15/20 minutes prior to start up (this thing heats up very quickly) and let it run at relatively low RPM for 10/15 minutes before I move it... I run 0-40 synthetic oil as well but even then -40 is bloody cold for any equipment even 2 stoke sled has a hard time at these temperture.
/ For those with block heaters #144
HOWEVER - I'm retired and have been for quite a spell. I have no reason to be anywhere at any specific time. When it's very cold outside - I find it's much better to just remain inside. Hot cup of coffee or chocolate and JD.
I'm retired now, baby. I'll go when I'm damned good and ready.
^^agree...If it is cold enough for the tractor to moan and groan when it finally starts, it is too cold for me also.
/ For those with block heaters #145
It's caused me to rethink my current home backup generator project. Instead of using an auto transfer switch, I'm changing to manual start for the diesel engine. The auto transfer switch allows only a 4 minute warmup before adding load. The recommended time in the engine manual is 10 to 20 minutes, depending on temperature. With manual start, I can make the call myself.
There must be variations between transfer switches and generators.
In my case the start-up delay is set on the generator, as is the time the generator runs after the power is restored. I increased both from the factory settings.
Also, instead of starting once a week and running a mere five minutes, mine is set to start one a month and then run for about 30 minutes.
To me the whole idea with a standby setup is to not have to go out and do anything manually.
/ For those with block heaters #146
I've seen ethanol wars, engine oil wars and brand wars. This thread is a new one for me: preheat wars.
One thing that is curious to me and that's our JD 410j TLB. It doesn't have a heater of any kind. No glow plugs and no intake heater. As far as I know its just compression. That darned thing will growl but pop off in the coldest of temps. It's not even that noisey once it starts. It's pretty amazing as other stuff, gas or diesel, really complains under the same conditions. I've pondered but never looked into a heater of any sort because the critter is never near an outlet and past extension cord range. I run 10w-30 Mobile1 in everything year around but we are in a moderate climate with ~5f being the coldest. I hate cold starting stuff in that weather, preheat or not.
So for me you do what works for you, where you are and under the conditions. To me, if the machine won't start then take a hint and go back inside (wink).
That's interesting. Ours too. It fires right off. Our 310SG TLB came with 6000 hours on the clock. It was used daily in a very cold climate by a concrete demolition company. From the factory they ordered it with factory block heater, fuel heater, remote ether injector, and a dual battery system.... but no glow plugs.
The only one of those extra cold weather systems that we use is the low wattage standard block heater - the same block heater our 16 hp Yanmar has.
During power outages I've started that 90 hp JD 310 often at 0*F or below without any preheat at all. I don't like to do so, especially after it has been sitting a few months - but sometimes there is no choice.
Like your JD 410, It fires up instantly - sometimes so quickly that it needs close attention to hear the starter crank. Settles down to a smooth idle and no unusual noises. None of our other diesel tractors or trucks starts half so well.
Whatever JD did to make their engines last so long has sure worked out. My buddy has a much older JD310 which starts and runs as well as ours.
rScotty
/ For those with block heaters #147
Some engines are worse then others for some reasons, but I would say -4F (-20C) is pretty much the limit for most diesel engines to start without help.
/ For those with block heaters #149
Glad I don't have those "most engines".
But yes, even basically identical ones do act a little different from each other at start-up.
/ For those with block heaters #150
Yikes! How did you figure that?
My point is there's ''usually'' no issues with anything hotter then that, anything colder then -4F that's when you start having issued without doing anything to help it. A smaller engine will start easier at lower temperture.
/ For those with block heaters #151
The generator is around 100' from the house in the back of my barn. I have it set up so I can control it from the house without going outside. I monitor it with a security system camera that I can view with my smartphone or PC.
/ For those with block heaters #152
Fair enough.
But if I wake up from hearing the UPS kick in, I prefer to just go back to sleep and let the generator do its thing.
At least neither of us need to get dressed and go start a generator, mess with breakers, etc.
/ For those with block heaters #153
Yeah, an auto transfer switch would be nice, and I would have gone that route if it weren't for the expense. My main breaker panel and meter are on a wall surrounded by concrete sidewalk and decorative landscaping. Much of it would have to be torn up to install a transfer switch setup.
Going overhead is a possibility, but it would involve installing poles. Everything is underground now and the wife is concerned about how it would look.
/ For those with block heaters #154
rScotty
Our 410j is model year 2010. But you got me wondering. I believe the engine is basically the same in 310 and 410 but JD has eked a very little more HP for the 410. Personally I love that it has a plain 'ol mechanical injection pump - not a computerized unit like in a Powerstroke pickups, etc. And the turbo doesn't have a bunch of electronics either. But the machine has no end of electronics overall. It seems most is for sensors, monitoring, BH joysticks, etc.. And thank the Lord that the wiring used throughout isn't a target of the mice and ground squirrels. One drawback is overall weight and height. When it was delivered it was on a lowboy pulled by a semi with the backhoe stretched out because it wouldn't have made it through the tunnels.
310 base model open center pump
310 se/sj/sk turbocharged PLC pumps, can have pilot controls basically stripped down lighter 410
410 more HP, turbocharged , few more options, mostly just bigger heavier with more power
Ps don't think powershift transmission is option in base model, option on se/sj/sj and standard on 410 size
Anyway, according to the long range weather forecast for our area, it's supposed to be warmer and wetter than normal so starting any of the equipment shouldn't be as much of an issue. Emphasis on 'supposed'.
PALLET OF HALF-BALANCE BALL TRAINERS (A64281)
PALLET OF...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
John Deere 6200 Tractor (A64047)
John Deere 6200...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
(1) UNUSED 12-16.5 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12-16.5...
