New garage time!
/ New garage time!
JFC I just want to hit hte button. But there's always "one more thing".
I hooked up all the panels in 3 strings of 5 to go to the inverter, I finished the conduit. I got the pv wiring done inside. I think I'm going to start with just 2 inverters in parallel until I get more batteries. And speaking of batteries, I need to finish the battery shelf, and finish building the battery pack.
***Speaking of battery packs, I started but accidently left them in parallel for balance charging for like 2 months, but I didn't take them to 3.65v, when I turned it off they were at 3.3x and now they are at 3.29v. ny chance I've accidently balanced them?
But when I went to hook up the set of rails, I realized that along with 1/2" bolt and lock washer, I got 7/16" nuts. So it was back to HD, and to my non-surprise, they were out of grade 8 1/2" nuts. So I had to grab regular ones. Not the end of the world but still. Over an hour wasted of time I don't have much of.
i need to hook up the inverters to the grid breakers still and make the bus bars for the batteries as well as the cables as well.
When I'm done, I'm going to write a manual on building a solar system volume 1, steps 1-1000. Followed by volume 2, steps 1001-2000, and I suspect I'm up to volume 8 now, but the good news is I can see the light at the end of the tunnel.
/ New garage time!
This is indicating that the female mc4 is negative, while the male mc4 is positive, right?
/ New garage time!
Ingenious use of the buss bar - is it code (honest question, I have no idea)? I used polaris connectors for something similar, though it was also in a much tighter spot
The only code violation i'm aware of is when 3 or more strings are joined there must be fuses.
I got around the issue by putting in-line fuses at the panel connections. The panel wire is 12ga, but the wires going into the joiner are 10ga. When there's 3 or more strings, the amperage is to high for 12ga in the event of a grounding worst case scenario. So between the panels and the wire from the box there are inline 20a fuses.
High voltage arc's, so there's that to consider. However it's 3kv/mm for arcing, so you would need 76,000v to arc an inch.
I'm going to get bigger bus bars to get rid of the strain/bends. The wire is not very flexible. I want it to come strait in.
/ New garage time!
I was not sure if 5s or 6s as far as voltage since my mppt is 120-250v, so I checked my voltage when the sun was almost set, to see where I stood.
I'm pleasantly surprised.
/ New garage time!
Got the bus bars installed and cleaned up and closed up.
Got the wires cleaned up, and the pv wires run.
I got the first inverter ONLINE! It idles under 30w.
/ New garage time!
Wondering your choice to provide battery backup over a generator for short term outages?
I don’t understand the question. I have a whole house generator. I’ve had to use it for weeks on end.
/ New garage time! #1,430
Ok then but why the battery backup? Isn't that redundant, or did I misunderstand your earlier post about batteries?
/ New garage time! #1,431
Are you talking about whole house backup batteries?
edumacate me :)
/ New garage time!
edumacate me :)
Yes, this will be an off grid setup. There's 2 types, grid-tie, and off-grid. Grid tie connects to the grid and feeds back into the grid your excess solar production. Off-grid charges batteries.
I have one battery pack, which I'm building now. It's 15kwh and the battery management system is rated at 100a. It's 48v, so the maximum drain on the battery is 4800w.
I have 6 inverters, each rated for 3000w, with a surge of 6000w. So even if I hooked up all of the inverters, I couldn't utilize them because I would hit the maximum discharge of the battery.
I needed power in the garage, and now I have it.
/ New garage time!
Batteries on charge to top balance, and started the battery room. It'll have room for 6 packs. It's 27" wide, 2x3's going up the wall for the shelves which makes the shelves 24" wide. The packs are 21.5" wide, so I should be good to go.
/ New garage time! #1,434
Ok, I didn't remember you were going off grid. You need something to carry you through the night and cloudy days.
I'm not a fan of batteries. i helped with research projects on many types for years. I know they are useful, and I can't live without them either.
/ New garage time!
Grid tie, permits, inspections, and the tie in fee's are thousands of dollars. Then you can't change anything. And the inverters are more.
I'm using LiFePo4 cells, which have a cycle count of ~8000, so I should be able to get a good 20 years out of them before they start degrading.
Before lifepo4 came along, i agree, battery was't the future, lipo and lithiums aren't safe and I wouldn't have them in my home. They only last around 3000 cycles, which isn't long enough considering the expense. Plus that whole fire thing.
Lifepo4 don't catch fire or explode, have high cycle count. But drawbacks are they're heavier, and have a lower max discharge rate.
/ New garage time!
I wanted to be there the first time I switched on PV, but I didn't want to lose time. and get some history. I do not get up with the sun, so I flipped it on and hoped I hooked everything up right.
And as it turns out, i did!
And as it turns out, it is the FIRST overcast day in 2 months, we're having an incredible drought.
/ New garage time!
Working on the battery closet still, not very exciting. Battery is still top balancing.
What is exciting is my ocean ev is charging entirely via solar, as it's a much sunnier day today.
From the charts I've learned a few things. Panels hit their voltage relatively quickly and maintain it consistently. The amperage fluctuates with conditions. Which is relevent when you consider startup and operating voltages of the mppt's. When 3600w of panels hit 42w of power, the voltage was 142v.
The inverter manual says startup voltage is 150v, operating 120v-250v, but it starts doing stuff before that.
/ New garage time!
So apparently cell compression is super important and relevant to getting the claimed cycles out of the cells. Between 3000-7000 newtons.
So wrapping cells in kapton tape looks like it's not going to be enough. So I reached out to hoover to get some 3/8" aluminum plate and all-thread. I figure if I'm going to do it, I'll do it right. They claim 21 years if I cycle the packs once a day, and i compress them. 7000 newtons is 1573 pounds. 10ft-lb of torque is 1600lb of clamp force, spread across 4 bolts is about 2ft/lb each should be sufficient.
Today's power has been much more consistent than yesterday. Yesterday was all over the place due to clouds.
Yesterday:
Today:
/ New garage time!
Getting slow progress on the battery shelf. I changed the design a few dozen times, but now I think I have something that will work, and give me 6 spaces for batteries, totaling 90kwh.
I have 10" of space for cells that are 8" tall, so that gives me a little space to deal with things.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
