Traner TR45/ FLand FR45
   / Traner TR45/ FLand FR45 #21
Well, Just sold the Traner45, so off to the Next Adventure.
I did acquire some knowledge, so any question I would be happy to "Try to" answer
Do you know the best transmission/ differential oil to use in this machine
   / Traner TR45/ FLand FR45 #22
I just used 80W Gear Oil in the Diffs and Transmission.
Do you have an oil filter number and how many quarts it takes when changing oil. Just purchased a tr45 this week no manual thank you
I just used 75w90 Gear Oil in the Transmission and Diffs.
No Number for the Oil Filter but a Baldwin BT223 for a Twin Briggs looks similar
   / Traner TR45/ FLand FR45 #24
Break down of the clutch.
Good afternoon; I purchased a 2024 traner tr45 and when first driving it - it ran fine was looking at posts here and filled up the oils as instructed in videos however now it will not move when running in gear. do you know anything that would make this happen with this tractor? looking for answers about how to get it moving now that I put the oil in it. also put in grease erks and changed motor oil filled up the hydro. oil but now it will not move starts fine just will not move. Any help is greatly appreciated
   / Traner TR45/ FLand FR45 #25
I received an air and oil filter and two spark plugs in my kit. It is the fl45. I will check fluids tomorrow. Do we go with other mini's for fluid choices as the book had none other than 10-30 for oil.
do you have number for air filter and oil filter for replacement?
and also spark plugs cannot find any information for these. Thank you
   / Traner TR45/ FLand FR45 #26
Good afternoon; so I purchased a 2024 trainer tr45 and filled all the oils on transmission and diffs. did you fill the transmission oil all the way? I had to go thru the top cap to fill however no way to tell how full it is as no dip stick for it. also after filling all fluids it now will not move it starts fine but will not move when letting out on clutch and putting it in gear any suggestions?
   / Traner TR45/ FLand FR45 #27
Hi there, sounds like I have the same issue with mine. I just picked it up at auction and ran it just fine for about an hour. Put it in 3rd gear and ran it for a few seconds before shifting it back to 1st and now it won’t drive. It has perhaps 1% power now. Enough to roll it forward or backward a few inches but that’s all.
Hoping someone here has some suggestions.
   / Traner TR45/ FLand FR45 #28
same here it ran really good for about a hour and then it started acting like it had no power I checked all the oils and fluids put filled them all put in grease erks, changed the oil new oil filter. adjusted the clutch filled the front end and back differencials with 80 w 90 oil. I am going to tear into it here soon cant today have other things going on but if I find anything I will post what I find on here. Hopefully didnt burn up and thing. At the moment it is up on blocks and when starting and running I can stop the tires movement with my hand at full bore.
Sounds like the Clutch is Stuck, Slipping.
Crown RC5535-35 Stand-On Electric Forklift (A59228)
Crown RC5535-35...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
