Traner TR45/ FLand FR45
   / Traner TR45/ FLand FR45 #11
Break down of the clutch.
   / Traner TR45/ FLand FR45 #12
I received an air and oil filter and two spark plugs in my kit. It is the fl45. I will check fluids tomorrow. Do we go with other mini's for fluid choices as the book had none other than 10-30 for oil.
   / Traner TR45/ FLand FR45 #13
Hello,
I recently purchased a Traner TR45 and the clutch is not working properly. Any one has an idea on how to adjust the clutch?
   / Traner TR45/ FLand FR45 #14
Congrats SignScape!
It's a neat Machine. Has some benefits over my Stand On, but also some draw backs.
Check all fluid levels. My Diffs and Transmission didn't have any.
The Valve Covers need to be swapped sides so you can add engine oil. Change it too quickly, it is oil but not engine oil.
Hello,
I recently purchase one, my first front wheel loader and I was wondering what kind of transmission oil (transfer case) would be appropriate to use on the Traner TR45? Can you share an example of a brand?
I just used 80W Gear Oil in the Diffs and Transmission.
   / Traner TR45/ FLand FR45 #16
Hello,
Make sure the clutch is engaging. Some owners have had the clutch sticking. Go to YouTube. I posted a video. Another guy has posted one also. Break out the wd40 for a quick fix.
Well, Just sold the Traner45, so off to the Next Adventure.
I did acquire some knowledge, so any question I would be happy to "Try to" answer
   / Traner TR45/ FLand FR45 #18
I bought one. Can’t find a manual anywhere. Make sure you go over all the bolts and fittings. Most of them were loose. I still need to adjust the clutch. Anyone else have one so we can pick each others brains. Thanks Bob
I bought one. After 20ish hours the clutch release bearing went and I'm currently ordering. One showed up and the numbers wrong. Maybe I can return
   / Traner TR45/ FLand FR45 #19
Anyone have any info? Good/Bad, Originating Manufacture. Pin Head is Threaded, is it Bored for Grease Fitting?
Any Mods needed?
Hi we're you ever able to find a manual or parts supplier for your Traner T45??
   / Traner TR45/ FLand FR45 #20
Just heard you sold. Did you lose money? I see them auctioning off really cheap...$3000, plus or minus.
Glad to see owners are sharing info about the clutch. Buyers are not going to be able to count on the makers, if known, to offer parts. I would continue to share info, and monitor eBay for sellers who offer items that look correct.
2007 Yamaha Rhino 660 (A56438)
2007 Yamaha Rhino...
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
JCB 3C 15' BACKHOE (A60429)
JCB 3C 15' BACKHOE...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
207274 (A52708)
207274 (A52708)
