international 234 mitsubishi K3B engine,
/ international 234 mitsubishi K3B engine, #1
boatmoter
Gold Member
plant city florida
john deere 212// john deere 320 // ford 2120 loader
Hi all, I have a international 234 compact tractor with a Mitsubishi K3B 3 cyl diesel. had a external leak at the injection pump, replaced all 3 Orings which solved the problem, now the engine won't shut down and runs wide open. I removed the pump and cleaned it up, inspection shows no broken or stuck parts. I need info on how to time the 3 small gears that turn fuel off and attaches to the rock shaft. I own a shop manual but it does not cover that part. the # on the pump is #094500-2190, they call it a cambox pump. THE 2 PARTS I NEED TO TIME IS # 11 (rock shaft) & # 7 sleeve-plunger control
/ international 234 mitsubishi K3B engine, #2
Two things. Not only the timing to set, you need to ensure the governor was not affected by the removal or install of the fuel pump. This would make the engine run in full throttle. I think item-11 you had pointed out could be the issue here.
The Yanmar fuel pumps are very much the same in that era. Likewise the Shibaura too.
There is a master fuel pump re-builder on TBN, @thepumpguysc
/ international 234 mitsubishi K3B engine, #3
Also see section-3 of this service manual.
You could of posted this in the Mitsubishi section of TBN too. ;) Lots more owners with your K3B engine there who have rebuilt these things many times over.
  • MITSUBISHI ENGINE K3A K3B K3C K3D K3E SERVICE MANUAL.pdf
thanks for the input. I did find the timing marks on the rock shaft and the (gears #7). I just assembled it and now waiting on the anaerobic- sealant I ordered. will reinstall monday and cross my fingers. everything seemed to look and go
together pretty well. I am got to keep the master pump builders Email. just in case and for future problems. also thanx on the heads up on the Mitsubishi section.
/ international 234 mitsubishi K3B engine, #5
did you download the engine service manual I had posted. It's a rare find.
yes, I did. but I have a shop manual I purchased 2 years ago too. yours is more used friendly. it is a cool manual
/ international 234 mitsubishi K3B engine, #7
yes, I did. but I have a shop manual I purchased 2 years ago too. yours is easier to read and locate the category's. it is a cool manual
Keep us posted on the final outcome. With the mess of the hurricanes down there, machines are in great need. Even compact tractor PTO power generators.
I'm an hour away from the Generac factory up in WI. Literally, they are working OT to keep up with the demand. I've seen literal convoys of semi's heading south on I-43 and I-90 full of all kinds of Generac gensets. Even the big ones on trailers using diesel engines.
will do. I had to evacuate here for Milton. the hotel I stayed at the first floor flooded with a foot of water, luckily I was on the 3rd floor. my car,in the parking lot got 3" of water on the inside where the parking lot flooded and it hurled a 2x6x12" and put a huge dent in my fender and hood. another guy had a BMW on the north side of the parking lot, the water was above his roof. it was a total loss. got home, unpacked on the Thursday after Milton and fired the /generator up. we had to run it from Thursday to Tuesday. finding fuel was almost impossible. finally waited until 2am and got to a 24hr station, it had fuel, but the line was 1/4 mile long. fuel ports at the docks were flooded and had lost power so no tankers could be filled. I will give updates on the injection pump, Im going to install it monday
installed the pump this morning and hooked up the Tie rod inside the pump and noticed the rod will not move. how to free up the Governor? I hope I won't have to pull the timing cover off the front of the engine. looks like a huge job.
re inspected & somebody hooked the tie rod from the Governor to a pivot post for a lever instead of the pin for the rock shaft. Im not saying any names !! fired it up, ran great, no more running wide open.. running on 2 cylinders. now no fuel coming out of the port of the pump for # 3 cylinder. pulled the pump again and getting ready to inspect # 3 port on the pump.
reinstalled the pump again after checking for any visual problems and it still has no fuel coming out of #3 port on the pump. time to try to get a pro to look at it
I sent you a PM
/ international 234 mitsubishi K3B engine, #13
AWESOME. Good to hear the MT is running nicely now.
As for port-3, did you bleed the line and remove the trapped air?
yes, when I did not get any fuel for cyl # 3 I removed the lines at the pump, 1 & 2 pumping great, not a drip out of # 3 port of the pump. sent the pump out to the pumpguy, on this forum, and he said the pumps in the assembly are worn out,it is a 1984. parts are ordered and waiting on it. I guess it pays to run bout 1/2 qt transmission fluid to every 5 gallons of fuel to lube the pump since the sulfur in the diesel is no longer and the older Diesel pumps depend upon the sulfur for internal lube.
/ international 234 mitsubishi K3B engine, #15
You did the right thing. @thepumpguysc would be my 1st course of action too. I know he has been so busy this summer and fall season. Glad you were able to get a hold of him.
For the fuel system lubrication, I use this. About 1/2 can every other tank fill up. MY machine is such a fuel sipper, it takes a long time before fillups.
