boatmoter
Gold Member
- Joined
- May 3, 2013
- Messages
- 251
- Location
- plant city florida
- Tractor
- john deere 212// john deere 320 // ford 2120 loader
Hi all, I have a international 234 compact tractor with a Mitsubishi K3B 3 cyl diesel. had a external leak at the injection pump, replaced all 3 Orings which solved the problem, now the engine won't shut down and runs wide open. I removed the pump and cleaned it up, inspection shows no broken or stuck parts. I need info on how to time the 3 small gears that turn fuel off and attaches to the rock shaft. I own a shop manual but it does not cover that part. the # on the pump is #094500-2190, they call it a cambox pump. THE 2 PARTS I NEED TO TIME IS # 11 (rock shaft) & # 7 sleeve-plunger control
