3320 Forward and Reverse Intermittently Stopping at Higher RPMs
/ 3320 Forward and Reverse Intermittently Stopping at Higher RPMs #1
pmqdflls
John Deere 3320
I have a 2011 JD 3320 eHydro with just over 500 hours on it. I've been using it regularly of late to move mulch, bush hog fields, tow a trailer around the yard, etc and no issues. When I went to do some tilling today the forward motion stopped suddenly – forward and reverse pedals did nothing. No strange noises, no drop or spike in RPMs, just no response to either pedal. After confirming I hadn't accidentally bumped into neutral, I shut the tractor off and checked the wiring under the pedals which seemed normal. Once I restarted things seemed to be working again so I assumed there was a loose connection or some debris, until a few minutes later when the same thing happened. What I eventually noticed is that if I throttle down all the way, they begin working again like normal. But as soon as the RPMs get up above 1500 or so, the issue repeats within a few minutes. I checked the oil level and that seems fine and the wires seem okay as well. No error codes have flashed, so I'm somewhat at a loss as to where to begin. Thanks for any advice!
/ 3320 Forward and Reverse Intermittently Stopping at Higher RPMs #2
Welcome to TBN
Hope others see your situation and can chime in to get you some help, or ideas to check something out.
/ 3320 Forward and Reverse Intermittently Stopping at Higher RPMs #3
Questions:
Does the same issue happen in A, B, and C speed ranges, or just in a certain range?
Does the issue happen with Mechanical front wheel drive (MFWD) on or off?
Does the PTO work correctly at low and higher (above 1500) RPM?
Questions:
Sorry for never replying to this, I somehow didn't see it and came back across my own post when I was searching for solutions (again).
At some point I did diagnostics and the pedal power all seemed normal, despite no forward and reverse. I had the idea that the problem was a clogged hydraulic filter that was getting bogged down and killing power to the pedals. So over the winter I did annual maintenance in addition to some other fixes and replaced the hydraulic fluid and filters. I started using the tractor again a few weeks ago and all seemed fine. I've mostly just been loading wheelbarrows with compost and wood chips, so nothing particularly laborious. But I have driven it back and forth to my folks place which is 1/4 mi away and no issues.
Until today. I was driving it down an access road and it started bucking a bit as forward motion seemed to get cut off and kick back in. I got to where I was going to load compost and after a load or two it was just not moving at all.
To answer your questions:
1. Happens in A, B, and C.
2. Happens with MFWD on and off.
3. I did not engage the PTO, but all other hydraulics seemed fine. Loader, 3ph, etc.
I should also note that no error codes are being thrown, and I didn't notice any obvious signs of issues with the electrical connections. Thanks for any help!
/ 3320 Forward and Reverse Intermittently Stopping at Higher RPMs #5
A mystery, for sure.
Time for a professional diagnostic at a dealer or service shop.
Best of luck figuring it out. Please let us know what eventually resolves the issue.
set of 4 tractor trailer tires Roadforce (A61307)
set of 4 tractor...
2006 Ford Crown Victoria Sedan (A61569)
2006 Ford Crown...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
00BBL WHEELED FRAC TANK (A60736)
00BBL WHEELED FRAC...
2016 American Eagle S/A Self Loading Reel Trailer (A60352)
2016 American...
