6/12v battery charger recommendations?
/ 6/12v battery charger recommendations? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
I've got several battery tenders & a smart 12v charger that will do up to 80@ as well as a jump pack or 2. Generally my smart charger does fine for most things.
However these days I also have a 6v 1966 JD 420 crawler loader in need of a charger & my current ones won't do 6v. I also recently mis diagnosed a bad starter I pulled out of the crawler. Hitting the terminal directly with a small 12v lithium jump pack failed to do anything. I'm assuming the smart electronics outsmarted me & were the issue rather than the starter.
Any sources for a good 6/12v old transformer style charger that isn't smart & will tolerate doing some dumb stuff like testing a starter out of the vehicle? Or are any of the modern 6/12v silicon chargers any good for charging & messing around with stuff?
/ 6/12v battery charger recommendations? #2
I was of the old school, transformer only chargers. Then I seen how this machine performed. None of my major brand name transformer chargers could successfully bring a battery back from literally the dead. When this one did 2 fully dead batteries back to life, I bought the charger. One dead was a 550CCA and the other was a 950CCA.
/ 6/12v battery charger recommendations? #3
I use a Noco 10 amp as an all around everything.
it can be forced to charge 0 volt batteries etc, and has a power supply option as well, does 6v as well as lithium
be aware there are no battery chargers that are going to make a starter work properly. a jump pack should give you the couple seconds to see it spin.
jump packs need to see voltage to fire up, there should be a light that comes on. otherwise you need to press the boost or whatever button to turn on the jump pack on super low batteries.
/ 6/12v battery charger recommendations? #4
Good Afternoon Fallon,
I am pretty sure you can find what your looking for at Harbor Freight ! I picked this charger up many years ago, both 6 and 12 volt with a start option ! I use it on my 6 v tractors and my Ford Model A !
I wasn't looking for "works properly", I was using a 12v pack on a 6v starter. I was hoping for a click & enough signs of life. I figured it was iffy to test & that the booster pack may have been the issue, but it's about all I had at the time. Starter is now repaired. Looking for something I can override like you mentioned.
I picked up a Schumacher Electric Wheeled Battery Charger and Jump Starter, SC1446, 2-in-1, Manual Timer-Controlled, 200 Cranking Amps, 6 Volt, 12 Volt, For Car, SUV, Truck, and Marine Batteries Amazon.com. Same thing & price as at TSC, but no hour round trip to pick it up. Time will tell if it was $150 well spent or not. Hopefully my automatic 12v unit keeps doing the unattended normal battery stuff. This should do fine for 6v, emergency starting & testing that smarts will try & thwart.
/ 6/12v battery charger recommendations? #8
Hit a few yard sales. Or marketplace for good old chargers.
/ 6/12v battery charger recommendations? #9
Just bought a NOCO Genius 5 off of the WhatNot channel for $8. A great deal for sure.
2018 Bobcat MT85 Track Loader Stand On Mini Skid Steer (A59228)
2018 Bobcat MT85...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2018 INTERNATIONAL LT625 TANDEM 6X4 SLEEPER (A59904)
2018 INTERNATIONAL...
