Good morning!!!!
   / Good morning!!!! #197,401
Thanks Scott and others. Will have to have a center for the pilot bit. Maybe wedge a piece of wood into the irregular shaped hole and hole saw it big enough to cover the hole and then use a 1/8 inch over to make the plug
Good suggestion
If you drill the desired hole into a 6x6 [or close] piece of 5/8 plywood you can attach that to the spot needing the plug and center it where desired. You can also take that board and clamp it to the donor board and drill straight thru without the centering bit. I did this to my house when I moved the outside faucet. Hope I explained it correctly!
50 here going to high 60's. Should be a nice day. Off to breakfast with the neighbor in a few hours.
Hope everyone stays safe and healthy!
   / Good morning!!!! #197,403
Great idea, follow you on how to do it. I have a few other places where plugs are needed and will use it there as well. A 200 year old house always has some challenges and finding workers that can help is like impossible
   / Good morning!!!! #197,404
good morning all
56 in Edgewood NM going up to 72 today
I am off at 9am first to visit the Indian Museum in Santa Fe and then continuing North into Colorado to Alamosa. I see it was 37 last night there, brrr.
first lots of coffee.
   / Good morning!!!! #197,405
61 this morning high in 70s more showers today nothing like last night raining over one inch per hour wild not sure of damage daylight coming. Wife had terrible day very angry.
Prayers for all our Country
   / Good morning!!!! #197,407
Loading bales on the 10th cloudy drizzly day in a row....
Thinking & praying for my brothers & sisters in the path of Helene
   / Good morning!!!! #197,408
That would be my suggestion also.
Yamaha (A55758)
Yamaha (A55758)
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
ALTEC CP12LF HYD (A52707)
ALTEC CP12LF HYD...
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54757)
(28) 4' FLOURESENT...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
