Making concrete from crusher run?
/ Making concrete from crusher run? #21
I always ordered transit mix truck then add a little water to make it runnier so it would make it’s way to the bottom cells, then vibrate or tap the block to settle.
/ Making concrete from crusher run? #22
Pump mix is typically used, and has smaller rock. Around here, CMU filled cells are almost always pumped. Lifting buckets up scaffolding isn't a lot of fun.
/ Making concrete from crusher run? #23
We would sometimes order 1/2” stone.
/ Making concrete from crusher run? #24
45-70; are there any "short batch" guys around or micro plants that rent a 1 or 1.5 cy tow behind ready mix trailer? There used to be a local lumber yard that did, but they closed 10 years ago. Now, about 1 hr north there is a small rental place that does. Closer, there is a guy that will deliver 1 yard in a ready mix trailer. It's expensive per CY; like $200+; but if you need less than 6 yards, it can be cheaper then playing the short load fees, delivery fees, environmental fees, ect of a full sized ready mix truck.
I've never used this company, just because of logistics; it's 1 hour away, and there is like a $60/hr fee for every hour after the 1st that you have it. So, in my case, by the time I got it home, it would need poured quickly, cleaned, and returned, maybe 1 hour later. Mean time, who is bull floating, edging, ect.
I've never used this company, just because of logistics; it's 1 hour away, and there is like a $60/hr fee for every hour after the 1st that you have it. So, in my case, by the time I got it home, it would need poured quickly, cleaned, and returned, maybe 1 hour later. Mean time, who is bull floating, edging, ect.View attachment 1346757
Nobody runs anything like that around here. The regular concrete trucks will bring small loads but a delivery fee applies. Even the full size loads are nearly $200 a yard after all fees are paid.
/ Making concrete from crusher run? #26
I have tried to talk Ace Hardware into it, I think the larger local Ace could do very well doing these small loads. My closest Ace is a larger store, selling everything from well pumps, ammo, feed, lizards/snakes/fish, and of coarse building supplies/tools/hardware.
Some of our bit more distant Ace stores are just the outdoor furniture, and potted plants...
How are they loading those small mixers? I have a skid steer mixer that works well but you have to load it by hand which kinda sucks. I suppose you could use the skid steer to mix the gravel and sand on the ground then scoop it and add the Portland by hand but if I was mixing a quantity where that method would really work I’d just call a truck. When I use that mixer I’ve always just used bagged concrete but it’s went up to like $7 a bag.
/ Making concrete from crusher run? #28
I'm pretty sure they have like a 5 yard sand and 5 yard #57 stone hopper, and I'm not sure it's manual Portland bags, 94# at a time, or if they have a hopper with a dryer. It's a really compact batch plant
/ Making concrete from crusher run? #29
Here is a place that sells the whole plant set up, and I think the towable redimix trailers too
Here is a place that sells the whole plant set up, and I think the towable redimix trailers tooView attachment 1347889
I could see owning something like that if your business involved a lot of small pours. I think a short delivery charge is $200. How much could you save renting that especially considering the time required to get it, wash it and return it? It also looks like it only dumps straight out the end. At least when you pay the $200 delivery it gets placed with the truck.
/ Making concrete from crusher run? #31
Around here, it's hard to get them to deliver less than 6 yards, and there when the whole aggregate shortage made it hard to get concrete, if they would deliver less than 6 yards, they made you pay for 6 yards...
Those kinda setups are good for a few panels of sidewalk, home owner stuff, or a 9 ft x 9 ft shed pad.
Even bigger jobs will have a few things like replacing broken curb or broken sidewalks.
But, as you pointed out, it is really only worth it as the customer if it's pretty dang local.
/ Making concrete from crusher run? #32
Concrete needs clean sand. It's usually washed first. I don't know the process but there's tons of river sand available cheap in Vancouver, B.C. and they haul in other sand for concrete. Bricklayers are also very particular about it.
I used one of those rental trailers once to do about two yards or less. Decided it's not worth the savings. When we needed a lot of concrete for fence posts, I'd bring a couple of yards of navyjack (sand and gravel mixed at the yard for concrete) and bags of portland cement. We'd mix it in 5 gallon pails with a home made mixer like a drywall paddle but smaller.
/ Making concrete from crusher run? #34
$2.57/60lb here.
Comes out to $150/yd
Dont know about Menards, but I avoid quikcrete from Rural King and other "farm" places, as it's often sat there for many months, and you'll get a lot of half hard bags.
Home Depot has like 15% off per bag when you buy the entire pallet; I think Lowes makes you buy two pallets to get the bulk discount. I have also had Home Depot want to charge me a $15 pallet deposit. I told them, then instead of setting whole pallet on trailer, yall can stack each bag; they waved the pallet fee...
/ Making concrete from crusher run? #36
A couple months ago price was almost $6. I checked today and thought if it's under $4 time to move on it. $2.57 even better so picked up 40 bags.
I just read the fine print - Menards will knock off an additional $.03 for volume pricing. Huh.
/ Making concrete from crusher run? #37
Looks like Home Depot is $4.48/60#; but I'm sure that varies store to store
/ Making concrete from crusher run? #38
3.88 for 50 lb. and 5.98 for 80 lb local Lowes. 10% off with bulk purchase
/ Making concrete from crusher run? #39
That's really pretty good at $154.20/CY; but also a lot of work. Those new "Muddmixer" mixers look like they make it easier/faster, but there is no getting around it still being a lot of work.
2015 John Deere 8295R (A64119)
2015 John Deere...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
