Making concrete from crusher run?
   / Making concrete from crusher run? #11
Works good enough for fence posts
   / Making concrete from crusher run? #12
I tried that 25-30 years ago because I was pinched for time. Within a few years, it was spalling pretty bad. I even threw in extra portland cement for good measure.
It will pay off in the end to use correct materials.
   / Making concrete from crusher run? #13
Always.
Trying to make concrete out of recycled concrete is not going to give the same result as properly mixed concrete.
   / Making concrete from crusher run? #14
Sounds like soil cement that you are trying to make, do some research on that, should be around 600 psi when made right. It's best done mixed in place, maybe with a tiller, soaked, graded, and compacted. How would you compact/roll once mixed, hydrated, and graded.
   / Making concrete from crusher run? #15
You need sand to fill the small voids between the crushed concrete. Fines wont be enough. Portland Cement is just the glue that holds concrete together, it's doesn't have any strength on it's own, so it needs something to bond to. Rock or gravel makes up the bulk of it, but sand is needed to make it 100%.
   / Making concrete from crusher run? #16
There's so much labor involved in mixing, pouring and finishing concrete that I'd stick to known proven ingredients unless the intention is to pour it around fence posts and you want to be able to break it up when it is time to replace the posts.
I was going to use the concrete mix to fill the cells in a block wall. The mix doesn’t need to be very strong for that job. It’s basically helping tie the blocks together. It’s not going to be visible so I don’t care how it looks. The main reason I’m debating trying it is my skid steer mixer can scoop out of a pile to load it but if I got the correct gravel and sand in a trailer I would have to shovel it in the mixer. Sand is also $40 a scoop at the landscaping yard so much more expensive than the crusher run.
   / Making concrete from crusher run? #18
Vertical rebar.
2014 FREIGHTLINER M2 REAR LOADER GARBAGE TRUCK (A51219)
2014 FREIGHTLINER...
Cat TH407C Telehandler (A52128)
Cat TH407C...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
More info coming soon! (A49346)
More info coming...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
