Making concrete from crusher run?
   / Making concrete from crusher run? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Has anyone tried doing this? I don’t really want to get small gravel and sand. I have plenty of crusher run already. I was thinking about mixing the crusher run with Portland cement. I don’t need it to look good and peak strength isn’t really a priority. If I got even 1000 psi from the mix I would be happy. I plan to load the crusher run and cement into a mixer and mix it not brush the cement dust on top of the gravel.
   / Making concrete from crusher run? #2
It's done all the time here at the local concrete plant. I had my concrete driveway replaced and the contractor took the pieces to the plant and I got some of it back mixed into the new batch after washing. Not as strong as stone.
   / Making concrete from crusher run? #3
I was considering that to cut down on the dust for a sidewalk.
I figured I would have to add a little sand to the mix it would save me a lot of work.
   / Making concrete from crusher run? #4
If it has fines in it that’s not normally used to make concrete. Would it work? Try it and let us know.
   / Making concrete from crusher run? #5
What are you using the concrete for. Dust is. Not usual ingredient in concrete
   / Making concrete from crusher run? #6
Some guy gave my dad a formula for mixing concrete that ultimately failed. I got the privilege of busting it up with a sledge. I don’t recommend experimenting when it comes to concrete. Stick to proven materials and methods.
   / Making concrete from crusher run? #7
3 sand 2 stone 1 concrete
I imagine the crushed fines could replace the sand
   / Making concrete from crusher run? #8
Watch out for steel wire mesh and your tires
This is crushed limestone not recycled concrete.
   / Making concrete from crusher run? #10
Might work for pavers etc. But the dust is going to kill any strength.
Unless you can wash it!
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
David Bradley Manure Spreader (A50515)
David Bradley...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
