Air Compressor Stalls Out
/ Air Compressor Stalls Out #1
JohnSchroeder
John Deere ST 135
I have a Husky Pro 60 gallon, 230V, 3.2 HP air compressor. Since I moved it from the basement to the garage it will no longer compress air beyond 30psi. It stalls out almost like the pressure switch is not functioning. I have replaced the pressure switch, the run capacitor, and the pressure relief valve.
/ Air Compressor Stalls Out #2
Have you checked that your cord is not damaged and that the wire connections are tight.
240 motors will not run at full power if one hot leg is damaged or loose but still allowing voltage to flow.
The damaged or loose connection will get hot quickly.
  • Good Post
Reactions: D&D
/ Air Compressor Stalls Out #3
Is the motor getting hot? Does it have a thermal switch that perhaps auto resets?
Check input voltage while running.
  • Good Post
Reactions: D&D
Thank you. What gauge wire should I be using from the switch to the plug? Does this need to be hard wired to the circuit?
/ Air Compressor Stalls Out #5
What type of plug are you using now? What’s the amp rating on the motor?
/ Air Compressor Stalls Out #6
I would say “hard wired” to the 220 side of the breaker panel..and have it’s own breaker..
/ Air Compressor Stalls Out #7
What is actually happening when you say it “stalls out”?
Like motor stops turning but is humming?
I tried to post the video of what the motor is doing, but the site does not allow the video format I am using. The motor continues to run, but slows way down and does not compress to more than 30psi.
I have a 40amp breaker at the box, I am using a 230 volt three prong clothes dryer type plug, 10 guage wire to the compressor and the motor calls for 15.4 amps and 230volts. I cannot hard wire since I share that outlet with my lathe, that is also a 230 volt service.
Thank you
John
/ Air Compressor Stalls Out #9
Thank you
John
How do you get the slowed down motor to finally stop? Are you unplugging it, or does the thermal protection kick in?
If the motor is slowing down, that would cause it to draw more current than 15 amps, and should start getting hot.
/ Air Compressor Stalls Out #10
I would suggest attaching a volt meter to the motor side of the pressure switch and monitor the voltage as it runs.
/ Air Compressor Stalls Out #11
10 gauge copper and and a good dryer plug and receptacle is more than adequate, as long as terminations are tight and clean and your wire length isn’t excessive.
/ Air Compressor Stalls Out #12
If he has one. Otherwise he can check for heat build up, somewhere between the breaker and the motor.
breaker, wires, plug and outlet should all remain cool to mildly warm. If there’s a hot spot, there’s your voltage drop
I never let it run once it starts slowing down to see if it was getting hot.
The cord is about 6' long. Based on where the compressor and receptacle are located, I could shorten it and check the connections. Thanks
/ Air Compressor Stalls Out #15
If you do have a multimeter, checking your running voltage would be the best.
Also, during your next run, check your air intake with your open hand, when the motor starts slowing down. Is it still drawing in fresh air in one direction? You’ll be ruling out an issue with the reed valve or whatever directional device yours uses.
/ Air Compressor Stalls Out #16
There should be a check valve in the plumbing from the pump to the tank. It's there to relieve tank pressure on a non-running pump. Often it's just a ball and spring.
If if gets stuck or gums up the pump will try to deadhead and the motor will drag down until it stalls. Been there twice and the symptoms here remind me of just that issue. Condensation caused some crud to build up and cleaning the little bits fixed it for me.
I've wised up and now drain tanks more often hoping to minimize such issues.
I shortened the cord, that was not the issue.
It was the same with the old check valve and the same condition with the new check valve. I still have the old check valve and it works like it should, so I don't think the problem is there. Thanks
I started it back up. The pressure switch is clicking on and off as it gets to 30psi. I let it continue to run. Good suction at the air cleaner inlet, so I know the reed valve is working. The voltage going into the pressure switch is around 119 VAC and going to the motor is around 117 VAC when stalling out. Seems low for a 230 volt system. The motor did heat up when it reached about 60 psi and then shut down.
/ Air Compressor Stalls Out #19
Is this a known 230 volt plug in you’ve used before? Is this a compressor that can run bot 110 volt and 220? Some can do both. I’m assuming the low voltage is the problem.
I use the same outlet for my lathe which is 220v and it works fine. This is a strange situation. Time to call an electrician. Thanks
2006 Vermeer BC1000XL Chipper (A61166)
2006 Vermeer...
Clark Forklift (A64047)
Clark Forklift...
2025 SKLP SK-PSJ220 Electric Jaw Crusher (A61567)
2025 SKLP...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
