Soft Treadle
/ Soft Treadle #1
Glink
kubota L3400 HST
My 2005 Kubota L3400HST Treadle went soft at the end of my last mowing session. Lost power in forward and reverse; tractor will move but cannot generate speed or power. First real problem with tractor since purchase in 2005. Tractor has a little less than 500 hours on it; most of it mowing a flat and smooth 5 acrea yard. All inputs appreciated.
/ Soft Treadle #2
I've heard there's a blue pill for that.
You did say all inputs.
/ Soft Treadle #3
Similar to the symptoms I had with my BX1500. The mechanic said it was a failure in the bearing cradle that varies the displacement of the hyd drive pump as you push the go pedal. For me it was 6/6 replace trans. For your much larger trans I think it would be replace the internal failed component.
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A63118)
2025 Wacker Neuson...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
Unverferth RHD1645DG-36 Rolling Rarrow (A63116)
Unverferth...
