Vehicle Oil changes
/ Vehicle Oil changes #141
My daughters Mazda 3 takes a little longer as I have get the ramps out, place them evenly and straight under the front tires, and then position the car on the ramps. Then undo the access panel underneath to get to the oil plug and oil filter. It takes a good 10 minutes for all oil to drain.
Yeah, getting the ramps out and putting them away is probably my single most time-consuming step, as well. I try to all of our cars that require ramps at the same time, to save the time of fetching the ramps out and putting them away.
As to time it takes to drain, I start with a warm engine, dipstick or oil filler plug removed to vent air, and then spin that plug off first. By the time I have the oil filter removed, the new one pre-filled with oil and spun back on, usually I'm ready to pug the oil plug back in. Total time might be close to your 10 minutes, probably a bit less, and then you're on the home stretch!
Then hope I have a new crush washer for the oil drain pan bolt.
I bought a box of 10 or 20 for our Volve T5, which also spec'd these, so I'd just always have them on hand. But prior to that, I did re-use them on at least two occasions, and it never leaked. Probably not something you can do indefinitely, but in a pinch when you don't have a fresh one on-hand, my experience has been that you can reuse the old one at least once.
After installing oil filter and putting in new oil, button everything back, put everything back in its place (tools, ramps) and then pour the old oil into my large oil container. 45 minutes or so.
Even that's fair, probably more time spent getting out the tools and cleaning up, if you're doing just one car. But that still beats driving to a service station, waiting on them, and driving home! Best case, I suspect that's still more than double your 45 minutes, for most.
/ Vehicle Oil changes #142
I wonder which will do more damage to your car... OEM-spec oil in place of AMSOIL, or being a dick to your mechanic? 😛
Short of our members who may be getting too old to crawl around on the ground under a car, or those otherwise injured/disabled, I have a lot of trouble understanding anyone handy enough and with the facilities to be into tractors... but somehow unable to change their own oil in their own car. Do they hire an electrician to change their lightbulbs, too?!? :D
It takes all of 20 minutes to change oil on a car, literally removing one bolt and unscrewing one can filter on most, then replace bolt and filter, and pour new oil in. If it's a pickup truck, you can even skip pulling out the ramps, and probably get the job done in under 15 minutes, if you hustle.
What do you recommend for low-mileage vehicles? Some of my sports cars see less than 3k miles per year, so it can be a decade before I hit the mileage recommendation for tranny or diff oil changes.
I do engine oil and coolant on a calendar schedule on low-mileage vehicles, yearly and six years respectively, but usually go just by mileage for other fluids. Not sure if that's best, but it has always felt logical.
Facilities to be into tractors, um, a shed with a dirt floor and no electricity. Vehicle parking is a gravel and weed driveway. I'd have built a garage years ago but I like to avoid property taxes when I can.
I've changed oil in the driveway with ramps many times but at 60 I've decided it's worth $25 to have Kenny do it on his lift. I also get to talk to Kenny for about 15 minutes and shoot the sh*t.
I change my own lightbulbs.
/ Vehicle Oil changes #143
45 minutes or even longer is worth it for me to guarantee this simple procedure is done correctly. Too many horror stories of oil changes at dealerships or other places.
A few years ago my son, while in college, took his car for an oil change. When he came home a few weeks later I checked the oil level and oil filter and found out they never changed the oil filter. It was the same one I had used with my writing of the date on it.
/ Vehicle Oil changes #144
Yeah. I might start hiring a mobile mechanic to come to my house to do oil changes as I get older. That way I can watch his work and supply the oil/filter.
/ Vehicle Oil changes #145
an old timer friend of mine ran a full service station here in town in the 60's. those were the days of plunge spouts for oil cans. he always had an empty can w/plunger installed. when he would check oil, mentioned it was a qt low, then invert the empty can in the crank case.
he bragged he made more money off that 1 can than gas or service. smart guy
/ Vehicle Oil changes #146
Did the same thing when I was a kid working at the local Pure Oil (remember them) station, The owner insisted we always check under the hood (was all full service back then) and if the oil or windshield washer was low to be sure to tell the customer it needed filled and if they agreed, we filled the washer bag with the same bottle of almost all water fluid and the same oil can that had little if any oil in it and then charged the customer accordingly. What a scam but it worked almost every time.
/ Vehicle Oil changes #147
A thief like that wouldn't have been a friend of mine at that point. And I wouldn't have an issue calling someone like that a thief.
/ Vehicle Oil changes #149
I'd have a 4-post now if I had a way to get it off the truck. They won't drop it with a lift gate, and it weighs too much for my tractor w/FEL. They said have it delivered to a business and pick it up with a trailer. I said, I don't have a trailer and how would I get it off the trailer if I did have one? :rolleyes: 😏
Maybe someone has mentioned this already, but some trucking company will let you pic the item up at their dock. I see you mentioned you did not have a trailer but could rent a uhaul or rent a dump trailer the day of the pick up. Of course the terminal needs to be nearby.
I would also check with the manufacture or the company that it is shipping from. I know the lift I have comes in several pieces. Could break the pallet open and handle them one at a time instead of a heavy pallet. Have a buddy or two help out.
When I moved my 2 post from one shop to another 4 of us could lift the posts carefully onto a flat bed trailer.
Be safe!
/ Vehicle Oil changes #150
It must be nice to live in an equipment wonderland like some of you guys do--Rent this, rent that. :rolleyes: It's a 50-mile trip in the opposite direction to get a trailer. Then a 50-mile trip to the "nearest" terminal and back. The terminal ordeal could be a 4-5 hour torture at the whim of whoever is there. Then another 50-mile trip to return the trailer. Not to mention the time to off-load the trailer a piece at a time with help or not. Oh yeah, then there's the cost of the rental and a full tank of gas. It ain't happening. If they won't drop it at/in my driveway like other equipment vendors are willing to do, I'm not buying it. My time isn't worth any less than theirs. Edit: I've seen flat beds going down the highway with lifts on the back. How about those? Vendors are so greedy.
That's how I just bought a flail mower. They delivered on the side of the driveway and inside the fence. There was a $50 charge for the lift-gate service. The poor driver had to wheel it off the lift-gate and through the dirt to get it off to the side. It's worth every penny to me and far less than renting any equipment. I was able to take my time to assemble it, lube it and get it back to the barn with the 3PH on the tractor. (It was also too heavy for my FEL.)
/ Vehicle Oil changes #151
Crooked guy is a better description!
/ Vehicle Oil changes #152
So you are crooked too, noted. My parents raised me better I wouldn't have done it.
/ Vehicle Oil changes #153
If you weren't in TX you could borrow mine.
/ Vehicle Oil changes #155
Back in the 70's worked for a very honest guy that had a chain of Texaco stations. He spiffed us on wiper blades, oil, and tire sales. Anybody that bought 10 gallons or more check the oil, clean all windows and check tire pressure. Our uniform shirts had a slot by the pocket for the pencil gauge. Any time he stopped by first look was ladies rest room for cleanliness. He taught me a lot about running a good service business.
/ Vehicle Oil changes #156
Back to the oil changes. I use the Mobil 1 synthetic oil on my vehicles. When the car is on the lift I check the tire pressures, rotate if needed, peek at the coolant, brakes, do the windshield washer fluid etc. Mt wife is a real stickler on the windshield washer fluid. It's got to be checked all the time even between oil changes. We have been married for over fifty years and accounting for all of the cars she has had I doubt if she has used even 1 gallon of windshield washer fluid over this time frame. Ta Da. I have a new 3/4 ton Chevy pickup and I have already changed the oil at about 3400 miles. The next oil change will be the free factory one at about 7500 miles??. I had put 140K miles on my last Chevy pickup and did all the oil changes at the 50% mark. The truck didn't use any oil that I could measure. I never had a trailer hooked to it, but the rear end started to make noise. The wife's Ford Edge, 4 cylinder, if I followed the factor schedule would be at 10k. That's not being done. I change that at about/ around 4K. Later
/ Vehicle Oil changes #157
I have found that a rounded head on a bolt or nut etc can
be removed using a pipe wrench or file them square and use a cresent wrench
willy
/ Vehicle Oil changes #158
I was an employee (and was dating his daughter as well), so I did what I was told to do. That was over 60 years ago btw. You seem to dwell on negativity for some reason. Maybe I need to put you on ignore.
I don't buy your comment either. You aint no saint.
/ Vehicle Oil changes #159
You are probably the, most negative guy on this site, dropping into threads with nothing productive to add other than to ridicule people for their decision, because they make different choices than you.
...or worry about grammar or misspelled words, who cares?
So, please DO ignore me! I'm tired of reading you BS.
So, I will tell everyone one of the problems. The place I take the work car, if it matters, Lube/Tire, in Starke FLa; Used to have 2-3 high school/early 20s guys/gals every time I went there, plus 1 or 2 senior techs. Past few years, I dont see the young guys anymore. So, I'm really not sure if it's a matter of "young guys just don't want to work" Or an employer saying, I can have fewer, more skilled guys, and make the same money, but they are no longer open on Saturdays, and waits are longer then a few years ago.
I do generally buy my personal vehicles tires online at Walmart, and 50/50 either get them mounted/balanced at Walmart or this Tire/Lube place. With Walmart, you get a kinda poorly balanced tire, and techs that get confused by anything other than the factory sizes. Other place, mount and balance 4 tires, that you bring in, might cost $100-150... But, they turn out right, And as someone who Has DIY mounted a tire in the front yard... I've learned I'm not DIYing that again.
Anyways, local Walmart has gotten to the point that a "free" rotate and balance, included for life with them mounting, is a 6 hour wait.
2015 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWEG0FL546478 (A61165)
2015 Jeep Wrangler...
2020 John Deere R4045 Sprayer (A63109)
2020 John Deere...
2013 GMC Sierra 1500 Crew Cab Pickup Truck (A61568)
2013 GMC Sierra...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
Decorative Horse Light Post (A61569)
Decorative Horse...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
