Vehicle Oil changes
/ Vehicle Oil changes #121
That's what mine are, wouldn't trade them for nuthin' . I've read a couple stories of those foam ones collapsing after a few years, granted they could have been the cheap ones.
If you were closer, I'd give you mine! As to collapsing, I would think stamped steel ramps are much more likely to experience a catastrophic failure with total collapse leading to death, versus foam ramps just partially crushing, if overloaded. But either one kept in good condition should never fail, unless overloaded.
My foam ramps have the max load (4600 lb.?) printed in large block lettering on the bottom of each ramp. I can't remember if my steel ones even have a max load label, I'll have to check next time I have them down off the wall.
If a foam ramp collapses, I'd want to know what load was on it, and how it was stored. They do come with warnings about storing in places like a hot attic, as the foam can degrade at high temperature. That might be their fatal flaw, and the one big advantage of having steel ramps, but I store mine in an air-conditioned shop.
/ Vehicle Oil changes #122
I don't remember if there was any background as to why they collapsed. Could have been out in the sun, heat or any bad storage practice.
I'd think that foam would collapse more catastrophically than steel, Steel I would think would bend before collapsing.
Each type has their own advantage or disadvantage.
No disrespect :), you stick with foam, I'll stick with steel LOL.
/ Vehicle Oil changes #123
I'd guess either could go either way. My thinking about steel catastrophically collapsing has to do with the design of the ones I own, which rely on a stringer riveted between the rear riser and the middle of the ramp portion. A rivet failure or damage to that stringer would severely weaken the design, and could lead to a catastrophic failure.
I'd really expect foam to partially collapse as an initial failure, rather than fully drop the vehicle to the pavement. A sort of crushing down from initial height to perhaps 70% height. But that's based more on crushing newer things made out of foam, than any formal engineering experience with these materials, or on how a ramp might behave after 20+ years of usage.
I do believe our society is far more litigious today, than 30 - 80 years ago, when a lot of these steel ramps were designed and built. So I'd be surprised if the new solution is less safe than the old, but again, a lot of assumptions in that. :D
/ Vehicle Oil changes #124
When i was on the volunteer Fire Dept we got a call about a man trapped under a car.
Back then I believe it was only the steel ramps. That’s what he had and he was pulling on the oil filter so hard he must have not been on the ramps perfect that both ramps tipped over and the car was on him, but also on part of the ramps and he couldn’t get out from under the car, we used airbags to get the car off of him and on my way back to work after the call I drove by the house to get to my job and he was already back under the car with it on the ramps again.
/ Vehicle Oil changes #125
One should never use the word "Jack" and "oil change" in the same paragraph, not to speak of sentence!
The steel ones I have are plenty strong, But the front "leg" of the stamped steel can/does sink into the sand. Never used the poly ones, but I'm assuming they cover for area to avoid sinking into the dirt
/ Vehicle Oil changes #127
I have been changing my oil, on my truck, tractor, Gator, the wife's car, daughter, granddaughter cars, a sister in law, niece's and an some neighbors for the last 30 years. I have a car lift which makes it convenient. Nobody has mentioned how they get rid of there oil.
I have the 15 gal plasitc drums that my brother in law used for chemicals on his farm. He takes a drum and or 2 per year to oil his barn cleaner chain. He is seventy and still farming. Ta Da. The remainder, I give to different garages that have oil furnaces. They are very particular about any antifreeze and or water mixed in with the oil. It plays havoc on there furnaces. In a normal year I collect around 4 to 5 barrels.
So much for the above. I wanted to describe a process to remove a rounded over drain plug. Sorry I didn't take any pictures but you should be able to visualize this process.
I had a friend that took his cars to the local quick change for his oil changes. On his last visit they told him they could not change his oil because they could not loosen the drain plug. They said the plug was all rounded off.
It was a Jeep so he then took it to the local Jeep dealer to see what they could do. He said they tried to remove it also but they could not. He said they had the special sockets designed to remove the drain plugs that were rounded over but they did not work. There fix was $1600 for a new oil pan. The oil pan was a plastic pan with a molded in brass and or bronze insert for the drain plug.
I suggested that he bring his vehicle out so we could work on it and to bring with him some hole saws like .62 .68. and .75 dia. and a couple of new drain plugs. If I remember correctly, we used the .62 dia. hole saw, with out the pilot drill. The rounded over hex acts as a pilot for the hole saw. I used one of my battery Dewalt drills on it's slowest speed and with in a couple of minutes had the drain plug out. This particular drain plug had the outer flange with the o-ring face seal. When cutting you need to be very careful to go slow and with light pressure. You don't want to score the brass and or bronze insert. Even before the cutter had gone approx. 2/3's of the way thru the flange of the drain plug, the drain plug made a slight rotation and I stopped there. Using the hole saw relieved the pressure on the flange of the plug. I then walked the plug out by hand. Another Ta Da. Later
I use an old 5 gal hydralic bucket to collect oil, and autozone/advanced will take a virtually unlimited amount, the local trash transfer will 5 gal per day per address. I dont separate hydralic, gear, motor, transmission, or "wash" diesel if it's not too noticeable. I dont put water gas, or acetone/thinner/spirits in the jug.
That more flammable stuff gets poured on a cold fire pit, and the next fire will burn off whatever residue is left in the ash.
Edit: one over looked advantage of having had a Kubota tractor, always Tons of empty hydralic buckets laying around ;)
/ Vehicle Oil changes #130
I know a few guys who use it for heating shops. I pour what I can back into the gallon or 5 quart jugs that I buy the oil in, and what's left over after that goes into an old 5 gallon gas can marked "used oil", then I give it to one of them. The gallon jugs are easier, since I can just hand them to a buddy at work or when they stop by, and not have to go retrieve my gas can afterward.
Love it! As I was reading, I was imagining you running the hole saw in reverse, just hoping for it to grab and walk the bolt out. But I guess you were running it forward?
One of my tricks for getting broken-off fasteners out of holes is to drill the pilot hole for the screw extractor with a left-hand drill bit. Half the time, the broken fastener will walk itself back out of the hole while I'm drilling it, totally eliminating the need for the screw extractors... which so seldom actually work.
/ Vehicle Oil changes #131
Here's my experience at my dealer's service department. In my online reservation and when I bring ours into the drive-in bay, I mention that I will be supplying my own AMSOIL oil which I placed on the passenger seat. This time I waited in the lounge after being in Tim Horton's for a coffee. An hour passed by and I get the call that it's ready, paid the bill, get the key and get into the car and to my chagrin my AMSOIL has not been touched. Without giving my brain time to strategize my next move I go inside and blow my stack to whoever, didn't care who heard me. Heads turn in my direction while some suddenly disappear. When I get mad, look out. In conclusion, their response was quick to replace their oil with mine in less than it took for a second coffee which they supply from a coffee machine. The dealer sent me an email for feedback on my experience. Needless to say that I gave it with "both barrels".
Which they took your Amsoil and used in their own car and did nothing but gave you time to get a second coffee ☕. Which is what I would have done if you went off on me. Not everyone is intimidated by that. 🤔🤔
/ Vehicle Oil changes #132
It sounds like there are a lot of people that don't change their own oil. It makes me wonder if an electric vehicle would be suited for people that don't want to do maintenance. I guess their dealer could change the cabin air filter if they don't want to tackle that.
/ Vehicle Oil changes #133
IMHO you should never flush out your transmission if its an
older model as there might be some sludge and it could get
jamed into a part of transmission and cause damage that you have to have a new transmission. Just a known fact!
willy
Have yet to find sludge, but not totally uncommon to find coolant from a failed radiator heat exchanger. This also causes transmission fluid to migrate into the cooling system. Blocking passages in the valve body or solenoids may be a possibility. As the clutch discs wear the friction material remains in suspension in the fluid. With a high mileage transmission this is a good thing actually adding friction to the clutch packs. Flushing the fluid removes the friction particles and can cause the transmission to slip, burning the clutch packs, and well you know the rest. Examination of the pan and magnet will hopefully show only fine particles and no bigger pieces. Regular fluid and filter changes started early will be a lot more advantageous using a quality filter and the best quality fluid for the brand. If it doesn't meet the OEM spec, it shouldn't go in. There is a reason I stock so many types of transmission fluids, engine oils, coolants, power steering and brake fluids in my business.
/ Vehicle Oil changes #134
I'd have a 4-post now if I had a way to get it off the truck. They won't drop it with a lift gate, and it weighs too much for my tractor w/FEL. They said have it delivered to a business and pick it up with a trailer. I said, I don't have a trailer and how would I get it off the trailer if I did have one? :rolleyes: 😏
A one day rental of a medium size forklift? I rented one for a week while erecting a steel building and it was reasonable with a quick learning curve. Yes the lift was too heavy for my little tractor, so we used it to pick up one end while the other side was lowered by the lift gate. I had a great delivery driver.
/ Vehicle Oil changes #135
You were hosed. In our region there is a chain called Prompto. Most full synth oil changed are in the neighborhood of $50. Looks like $90 for something STR specific.
WOW, not here. Depending on vehicle, $125 - $200 or more. Couple jugs of T6 will run more than $50 and a Motorcraft Diesel oil filter is maybe $25. Without an upsell, I still need to make something for my labor. And I use a torque wrench on the drain plug. DIY is fine as long as the OEM service recommendations are followed.
/ Vehicle Oil changes #138
I wonder which will do more damage to your car... OEM-spec oil in place of AMSOIL, or being a dick to your mechanic? 😛
Short of our members who may be getting too old to crawl around on the ground under a car, or those otherwise injured/disabled, I have a lot of trouble understanding anyone handy enough and with the facilities to be into tractors... but somehow unable to change their own oil in their own car. Do they hire an electrician to change their lightbulbs, too?!? :D
It takes all of 20 minutes to change oil on a car, literally removing one bolt and unscrewing one can filter on most, then replace bolt and filter, and pour new oil in. If it's a pickup truck, you can even skip pulling out the ramps, and probably get the job done in under 15 minutes, if you hustle.
What do you recommend for low-mileage vehicles? Some of my sports cars see less than 3k miles per year, so it can be a decade before I hit the mileage recommendation for tranny or diff oil changes.
I do engine oil and coolant on a calendar schedule on low-mileage vehicles, yearly and six years respectively, but usually go just by mileage for other fluids. Not sure if that's best, but it has always felt logical.
/ Vehicle Oil changes #139
No problems getting rid of used oil here. The town highway garage will take all they can get for their oil burner. It's not uncommon at mid winter to see posts from people seeking used oil, some pay a few bucks for large quantities.
/ Vehicle Oil changes #140
The mechanic in that situation could have easily taken that Amsoil oil and poured it in the recycle container and still kept the original oil in the car.
My daughters Mazda 3 takes a little longer as I have get the ramps out, place them evenly and straight under the front tires, and then position the car on the ramps. Then undo the access panel underneath to get to the oil plug and oil filter. It takes a good 10 minutes for all oil to drain.
Then hope I have a new crush washer for the oil drain pan bolt. After installing oil filter and putting in new oil, button everything back, put everything back in its place (tools, ramps) and then pour the old oil into my large oil container. 45 minutes or so.
Now my EV oil change is the easiest ever! :geek:
I use Rotella T6 synthetic diesel oil for my F250 and Mobil 1 synthetic for any other ICE car. Once I sell my F250 ima going all EV and thumb my nose at oil changes (except tractor) forever.
(APPROX,9) UNUSED KJ GALVANIZED WELDED WIRE MESH (A62131)
(APPROX,9) UNUSED...
Decorative Turtle Statue (A61569)
Decorative Turtle...
COUNTY LINE 300 GALLON WATER TROUGH (A62131)
COUNTY LINE 300...
YALE GLP050RGNUAE086-LP STRAIGHT MAST FORKLIFT (A62129)
YALE...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
HOMEMADE 25 GALLON ELECTRIC AIR COMPRESSOR (A62131)
HOMEMADE 25 GALLON...
