Radial tractor tires
/ Radial tractor tires #1
Mike rich
2650HD
Can you fill radial tractor tires?
/ Radial tractor tires #3
My owners manual shows how much to fill my radial tires with liquid. Just off of memory, I think it's 3/4 of the tire can be filled.
/ Radial tractor tires #5
Yes they can be filled but you may notice a stiffer ride since the fluid fill slows the tire flex some. Air compresses while water has to be moved to compress the air in the tire. Smaller air volume equals greater pressure change with tire movement.
/ Radial tractor tires #6
Most ag tire manufacturers do not recommend liquid ballast in radial tires. I have two tractors with radials and liquid ballast, and one tractor with radials and wheel weights. All other tractors have bias rears with liquid ballast. I do not like liquid ballast in rear radials, it negates some of the positives of radials and has a very bouncy ride on the road, I suppose due to softer sidewalls and liquid movement.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
UNUSED CFG INDUSTRIAL MX20R MINI EXCAVATOR (A62130)
UNUSED CFG...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
Year: 2017 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 45,678 Plate: Body Type: 2 (A61568)
Year: 2017 Make...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
