Tires Dumb newbie question on filled tires
   / Dumb newbie question on filled tires #1
Santa Craig Cringle
Lawrence County, AL
Current - 2021 Kioti CX2510, Previous - 1959 Ford 881
First time owning a tractor with beet juice filled tires. So, how exactly do I maintain them? They look like they could use a little air but I’m not sure, but do you even air up filled tires?
Told you it was a dumb newbie question.
   / Dumb newbie question on filled tires #3
Yes drive the tractor till the valve stem is on top, then it helps to give it just a short blast of air to clean out the stem before checking the pressure.
If you get fluid in your tire gauge the best way to fix it is take it to the kitchen sink and rinse in warm water while exercise the stem.
Do you have an idea of the pressure you are wanting to run?
It will not be the sidewall marked max pressure.
   / Dumb newbie question on filled tires #4
What LouNY said. On pressure, most are going to run a pressure below that which is stated in the manual, as air space (and thus cushion volume) is much less than on an all-air-filled tire. I think I have mine set right at the minimum of the range specified in the manual for this tire on this machine.
Just don't go too crazy low, and walk the tire off the rim. Your eye is a good guide on inflation level, the gauge is more just to keep the two sides even with one another.
Hadn't thought about it actually. I suppose I could call my dealer and ask them what they set them out when they send them out the door.
   / Dumb newbie question on filled tires #7
When I check the rear tires on mine, I typically lift the rear wheel with a jack and check it so the weight of the tractor on the tire is not pushing water out. I don't get any liquid on the tire gauge and get an accurate reading. I'm just running straight water too.
   / Dumb newbie question on filled tires #8
Not an option for most of USA, as half our tractors would be frozen half the year, and most would experience at least some occasional freezing.
Some use various antifreeze products, either windshield washer or RV antifreeze, but these have relatively low density. That may be fine for someone not wanting max weight in their rear tires:
Beet juice / bio ballast / CaCl2: 11-12 lb/gal
Water: 8 lb/gal
Antifreeze solutions: 7-8 lb/gal
I went with a 60% fill of beat juice, to hit my target weight, and still keep some cushion in the tire. I am not sure how that will fare for corrosion, time will tell.
   / Dumb newbie question on filled tires #9
I just look at mine most of the time, I'm looking for a decent sidewall bulge and a full width contact patch. In moderately soft ground it should be leaving a flat foot print, on the hard gravel roadways I expect to see a good foot print. Then I'll use a gauge to verify I'm usually around 10-12 PSI with heavy 3 point loads I may go up to 15 PSI.
500BBL WHEELED...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
