This can’t be right can it?
/ This can’t be right can it? #1
TNed
Yanmar 1510
I just acquired a Yanmar 1510. Rear hydraulics not working so drained the fluid. It is very milky so appears to have water in it. Then I notice the fill cap has a hole going through it. I could imagine there might have been some type of upper piece that allowed the hydraulics to vent but this just lets rain water right in. Is part of the cap missing or is it supposed to be like this?
/ This can’t be right can it? #2
Suspect missing the breather part of the vent but not certain how Yanmar made that part
/ This can’t be right can it? #3
Welcome to TBN!
Yes, that part generally has a plastic over piece (outer cap) to prevent water from getting in.
Was there any rust or clumps when you drained the fluid? Did you clean the hydraulic pump intake screen? It often clogs after water has been in the system for a bit.
All the best,
Peter
/ This can’t be right can it? #4
Rice patty water was my guess. The bottom of my Hyd. Oil pan had at least a inch or so of dirty super nasty Hyd. fluid. Thick as Crisco! What it looked like to. Had to replace my Screen or it was best I replaced it.
/ This can’t be right can it? #5
Definitely looks like it was a 2 piece cap and the outer shell is missing, though a quick google didnt bring up a pic of it.
/ This can’t be right can it? #6
the only thing I came up with was the strainer cover 186,1510 IP-4300. Does this look like it might work?
/ This can’t be right can it? #7
After looking at the pic and the open threaded hole just below it. That should be a vent tube. Normal esp. in between the lift arms.
/ This can’t be right can it? #8
its clearly missing a piece simply based on the uv damage on the outside and not the inside.
I just acquired a Yanmar 1510. Rear hydraulics not working so drained the fluid. It is very milky so appears to have water in it. Then I notice the fill cap has a hole going through it. I could imagine there might have been some type of upper piece that allowed the hydraulics to vent but this just lets rain water right in. Is part of the cap missing or is it supposed to be like this?View attachment 1220669
Thanks for the comments. Any of you fellas with a 1510 that could send me a photo of what that cap is supposed to look like. I would appreciate it. I’m not finding the part anywhere online. Not sure if it is a solid cap or a breather type cap.
/ This can’t be right can it? #10
I would bet its vented. You might be able to get NAPA or Farm Store to try and match it, at least in fit. Try JD dealers as well as they always seem to be able to get oddball parts.
/ This can’t be right can it? #11
This is the only one I could find
/ This can’t be right can it? #12
Ok.. Doing a little search, I found this Parts Manual, but its in Japanese?
https://cdn.shopify.com/s/files/1/1486/5356/files/YM1510D_Parts_Manual_DONE.pdf (free d/l so save a copy)
Looking for the part, on pages 79 and 80 (as counted by the pdf reader) I see a Filler Cap #15 which is listed as p/n 194990-75170
Searching for that, I found this page saying it was replaced by p/n 194065-18410 listed here
A search for the 18410 cap showed several dealers but they all seem to be actually from Parts ASAP at $12-$15 w/ $15 shipping.
Hope that helps! 😁
/ This can’t be right can it? #13
Hope that helps! 😁
You can get it FREE on this site too, nearly ALL the listed models in that thread have a manual. And NO watermark on it either.
Japan copyright pre-2011 for out-of-print and single use download says it can not be altered for the 'original' pages. Now, anyone could add their own cover page.
/ This can’t be right can it? #14
Nice pics and good thread. :)
Did a quick search here and that thread never popped up.. ? Dunno, search here is weird sometimes
/ This can’t be right can it? #15
The search tool here has been broken since the day I arrived a decade ago. I do not use it. Use a search engine instead.
Yeah, I put lots of time, research and effort for that thread. It's the go-to thread for new owners or others who would like to compare models.
The other threads I have are for fun. Like the, YanDeere. The site owner loves it! When a new YanDeere is posted he goes a looking there. :p
/ This can’t be right can it? #16
Still no part # only if it is vented! Just seen a 1510 model. Seems to be in really nice condition!
2021 TAKEUCHI TL12R2 SKID STEER (A64279)
2021 TAKEUCHI...
213120 (A64276)
213120 (A64276)
2011 Renegade Mobile Command Center Trailer (A61573)
2011 Renegade...
2006 Freightliner Box Truck (A61573)
2006 Freightliner...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
(1) UNUSED 26X12.00-16 TIRE W/ 5 LUG RIM (A64280)
(1) UNUSED...
