Grimspyder
- Joined
- Sep 18, 2024
- Messages
- 14
- Tractor
- Ford 4500 Industrial
Hello everyone, I hope you guys can help me figure out an issue I am having.
I need to know which fuel pump I need to buy.
(Very long story, Short)
I have a Ford 4500 Industrial Backhoe and I had hired a mobile diesel mechanic to get the tractor started ( I couldn't figure it out, and no longer had the time to work on it ). He tried to scam me out of thousands, and in the end disappeared with the original Fuel pump.
I am pretty sure the issue is the fuel pump, I had narrowed the issue down to that and tried to rebuild it. But I think I ordered the wrong kit ( according to a guy that rebuilds them online ) and probably messed something up also.
But since I do not have the fuel pump, I am not sure which pump I need to order. I have attached some pictures of the engine and the rebuild kit I ordered in the past. One issue with the rebuild kit was that the top cover set up was different than the original so I just used the original cover. I figured it was just a different model and did not affect function.
I was hoping someone could help me figure out which pump I need to order. I have tried looking up the engine numbers to see if I could locate the correct pump, but I have not been able to.
Oh' Ill need to order injectors also, that POS took of with those also. And those got rebuilt also.
Any help would absolutely amazing, I would like to get running before winter.
I appreciate any help.
Thanks.
Thanks.
