Small (tiny) combine - pull type - for grains?
/ Small (tiny) combine - pull type - for grains? #21
I grow a couple acres of buckwheat per year. I cannot fathom the work involved in hand threshing 1/4 or 1/2 acre. 🤯. You are talking over 500 pounds of seed!
How do you harvest your buckwheat?
/ Small (tiny) combine - pull type - for grains? #22
Right now I don't, I till it under to self seed. One acre requires 100lbs to seed, but will produce 1000-1500 pounds per acre. Plenty of small, older combines around here that could do the work though.
/ Small (tiny) combine - pull type - for grains? #23
Excellent input. I am very interested in your idea and progress.
From the sounds of it I think you are addressing one major question I had with the idea of cutting in the field and transporting for processing. I am not sure that we will get to the point of having even 1/2 acre of any particular variety/crop so if those are the numbers you are working to and are going down the road of transporting the cut crop to process out of the field that interests me very much. Can you elaborate on your thought process on this?
The contraption in the video with the powered drum to do the threshing looks like it may be effective on a small scale. However, how does that sit with your numbers on the acreage/production over those acres? What are your transportation plans - both the fresh cut crop to where you process and the chaff post-processing? Do you have a thought process on how you are going to feed the crop through the threshing process at a volume that meets your estimated production?
So, full disclosure. I'm not a farmer and I'm not a fabricator, so don't laugh. :ROFLMAO: I'm a long time IT guy who spent some time on a friend's family farm in my younger days, with a strong DIY streak and a desire to be more self sufficient. I don't have any plans to sell grain, but am interested in experimenting with some of the heirloom grains as a way to reduce gluten intake. My daughter is gluten intolerant, which got me interested in this.
Here's a short video of the thresher as it currently sits and the theory of operation.
I still need to add some baffles for air flow and I need to fabricate some kind of bracket for mounting the motor inside the back open area. I'm going to try this with a 1/2 HP motor that I have sitting on the shelf. If that isn't powerful enough, I'll swap it out for a 1 HP model. I did some basic CAD drawings for dimensioning purposes, but don't have a material list to go with it. If it looks like something you're interested in, I'm happy to share.
As for your questions about the logistics, I'm not certain what to expect. The machine is pretty heavy, but adding some wheels would make it easier to move around in the shop, which is where I plan to do my threshing. It will have to be hand fed, so it will still be a slower process than a combine, but a lot faster than trying to do it by hand. My goal is to have a two stage solution for threshing and winnowing. I know it won't be perfect, but hopefully, it's good enough.
As for portability, I suppose that I could mount it on a pallet and move it out to the field and use a generator to power it. I hadn't really thought about that.
/ Small (tiny) combine - pull type - for grains? #24
What is the purpose of the buckwheat if it’s not harvested?
/ Small (tiny) combine - pull type - for grains? #25
Green fertilizer.
Cover crop that unlocks phosphorous in the soil. It grows fast, also, and in dense stands (high population) it can overtake weeds. It also promotes healthy organism growth in the soil.
Tilled in the organic matter is, furthermore, good for the soil.
Edit to add -
The principal of "cover crops" is something we are studying. There are numerous directions to go with it, however with the right application of crops to soil you can do any number of things. Around here (central Ohio) farmers use field raddishes to add organic matter and break up compacted soil, among other benefits.
If you dig in to the subject of "cover crops" youll find a whole other world within agriculture.
/ Small (tiny) combine - pull type - for grains? #27
Good nectar source during the dearth. Grows easily, fast, produces tons of organic matter, smothers weeds...
/ Small (tiny) combine - pull type - for grains? #30
I can buy an old JD self propelled combine for $3000, that's operational around here. If I were looking to harvest an acre or more, I'd look into an actual combine. Or a person with one. I simply don't have weeks to devote to hand threshing grain. The cost of an older unit for artisan farming would be worth it.
/ Small (tiny) combine - pull type - for grains? #32
Cover crop that unlocks phosphorous in thrle soil. It grows fast, also, and in dense stands (high population) it can overtake weeds. It also promotes healthy organism growth in the soil.
Edit to add -
I understand the concept of cover crops, but they are typically a short term soil management strategy for lands intended to grow other crops.
/ Small (tiny) combine - pull type - for grains? #33
Planting part of the property to buckwheat also reduces mowing time and control of noxious weeds. If I can till, plant, till... It's less time consuming than mowing it 7x per year. Not to mention it's absolutely beautiful when in bloom.
/ Small (tiny) combine - pull type - for grains? #34
A word of caution on threshing grain inside of a building is that under certain conditions the dust can be explosive. I have clue exactly what those conditions are but the explosion usually is quite dramatic.
In the old days people used to build shocks of grain both for drying and transport. Seen this done as a youngster but never actually did it. Have handled the shocks though using a pitch fork to load wagons.
Wish you the best on getting that threshing unit figured out.
/ Small (tiny) combine - pull type - for grains? #35
I really appreciate the heads up. I guess I won’t be doing any threshing in the shop! :unsure:(y)
/ Small (tiny) combine - pull type - for grains? #36
This should do the trick ! 44 acres an hour !
/ Small (tiny) combine - pull type - for grains? #37
Most grain explosions are are at the mills were it is being ground or in large elevators were the grain is being moved swiftly and creating fine dust.
/ Small (tiny) combine - pull type - for grains? #38
Would an electric leaf shredder, and a high volume fan at the discharge, do the trick? You still have the cutting/gathering side; but a sickle bar mower, and then the less than fun gathering phase. If we are talking well less than an acre; that would probably do the trick.
If you had the leaf shredder, a generator, and a high volume fan, with your "hopper" maybe a IBC tote; and put all that on a trailer; your chafe would be blown back into the field too
/ Small (tiny) combine - pull type - for grains? #39
Or, a set up like this, pulled behind the tractor, and a trailer for the blow heavier grain. You would want/need a ground person running the vac hose; and someone on the tractor or ATV. I'm thinking you would end up with a semi processed grain at the outfeed, with the trash just blowing away, and the heavier grain dropping in a small trailer.
/ Small (tiny) combine - pull type - for grains? #40
When we lived in Upper Lake, there was a vineyard/winery across the road from our friends on Tomki Rd in Redwood Valley that planted wheat between the vines for crop/harvest/cover and I think they were going to sell breads, flour, or make Whiskey?
Frey Vineyards in Redwood Valley, CA.
They had a mini combine that would fit between the vines.
They got hit real hard by a forest fire about 8 years ago and lost most of everything so I'm not sure if they're still doing the wheat thing.
I'm trying to post a picture of them and their little combine.
Patrick
Zero Turn Mower (A59231)
Zero Turn Mower...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
