How much do you care about pre emissions
   / How much do you care about pre emissions #61
I find most everything from the Gubment is exaggerated to fit their agenda.
If you want to talk about harm to humanity, just look at what these "experts" put in our food. And people wonder why they have cancer and other ailments.
Thank God I survived swimming in a creek and drinking out of a garden hose.....and riding a bike with no helmet or God forbid, I rode in the back of a pickup!! I even drove a beat up old 1961 Chevy pickup when I was 12.
We need more common sense and logical thinking.
Just my opinion....
M
   / How much do you care about pre emissions #62
Assuming global warming is a fraud (which I'm 100% sure it is at this point; we haven't even reached Temps of the medieval warm period); what urgent environmental problems are we facing? Fresh water in some areas, yes, but that's not generally a pollution issue. Landfills overfilling, like they told us in school, zero signs of that. Running out of oil in next 50 years, nope. Acid rain, nope. Lithium shortage, no, they've discovered vast amounts in Chile, Boliva, Afghanistan, ect.
The only issues I really know, are mostly legacy issues; old landfills leaking contaminants, old pole pole treatment yards, old gas tanks left in the ground, old lead/asbestos. Yeah, there is a nuclear bomb in the ocean somewhere off S. Car allegedly dropped in an airforce incident; but that wouldn't go up, and it is probably no more than a blip in the ocean,
Climate change has become this convoluted term that really has no definition, by design. One distinction that needs to be drawn is the difference between pollution and climate. They are two completely different things, but they get lumped together in the debate.
Do I think US society both in terms of ideals and practices, dealt with pollution. Yes. Outside of spontaneous polluting events like a train derailments, the US has largely solved the pollution issue.
Now climate is much harder to deal with because of mother nature. I have not seen any evidence put forth that says, this region should be a temperature of "x" and have a participation amount of "y". Then get to these stated goals by doing the following...
Now since there is no scientific way to identify the problem and a way to solve the climate problem, we get these platitudes that are rooted in pollution reduction. Again, largely solved.
So logically, since we have done great strides in eliminating pollution, shouldn't the climate respond to these actions?
   / How much do you care about pre emissions #63
Agree , direct pollution should be minimized wherever technically and economically feasible.
“Climate change ®” on the other hand is a separate subject and one of major gaslighting of the masses
   / How much do you care about pre emissions #64
Here's a graph of CO pollution from areas mostly in California for 1970-2018:
It's too busy a graph and just one pollutant, but the idea comes across.
However while the levels are lower, they're not zero. I still see a sick looking greenish layer in the air above Silicon Valley often in the summer when the inversion layer traps the smog from a million cars in the valley.
   / How much do you care about pre emissions #65
I do care about emissions. That's why I bought TYM 😜
   / How much do you care about pre emissions #66
It will never be ZERO, the regulations in place by 2000 had done the "needed" drop and it would have and still would be slowly dropping without any additional interference from the government.
   / How much do you care about pre emissions #67
So if the Saudi's are using more resources to get more fuel to market and then the US has emisisions...is there a per unit benefit globally?
Since most people can't think beyond what their two eyes see...they think the US is all unicorns and rainbows while ignoring the production side.
   / How much do you care about pre emissions #68
I have a pre-emissions Case DX35 and have thought about moving up to a 50-60 HP compact. I was looking at a used Kubota L6060 with a DPF and still not sure if I want to buy. Dumb question inbound. Do the new tractors that use exhaust fluid still regen or did the fluid make that unnecessary?
   / How much do you care about pre emissions #69
A bit off-topic but here's my take on Climate Change.
I’ve been a weather watcher for over 50 years and keeping records of extreme events but a few years ago when I retired I started keeping my own accurate records. I met someone that has over 50 years of his own accurate weather records. I asked him what the biggest change has been since he started keeping records and he said warmer nights that the daytime temperatures overall have hardly changed at all. Well naturally the nighttime temps are pushing up the averages overall but higher nighttime temps aren’t nearly as bad on this old rock as daytime temps. I also concur it’s mostly warmer nights, daytime temps have hardly changed at all for the majority of us.
You can’t always believe these computer models or numbers the weather folk are putting out either. Back in Spring 2023 we had almost 4.5” of rain in a two day period. The biggest local weather person, whom calls himself a scientist, said our area only got 0.03” of rain during for that period. Everyone was like are you high on something. That day in 2023 he said we’re low on rainfall for the year. We had already had 34.7” of rain here so far that year. If we continue that trend we’ll be looking at 57” for the year or 15” above average. The problem is every county I believe in the country only takes one measurement for their official record keeping and usually always near an airport. What do all airport have in common, lots of concrete, asphalt and no trees. It’s probably the worst place to use for weather record keeping and it’s no wonder they’re showing a steady rise in temperatures with all that hard surface being added continually and no natural cooling from trees. I could talk forever about weather but I’ve gone on long enough.
Also we're still warming from the last "Little Ice Age" that occurred 1560 to 1630 for when the worldwide glacial expansion, known as the Grindelwald Fluctuation, began 1650, not the start of the Little Ice Age, but the start of the coldest years midway through, i.e., the First Climatic Minimum. The Little Ice Age ended in the latter half of the 19th century or in the early 20th century.
BTW: The latest trend in mainstream weather is to only go back 30 worth of records for comparisons. I say go to where we started keeping accurate records, around 1883 in many places.
The exhaust fluid is only used in 75hp and greater, as far as I know. I don't "think" it's a specific requirement, it's just the easiest/cheapest way to get to the required numbers. That could be mistaken, so I would research myself. But basically the regen is just a self cleaning cycle to burn soot out of the filter.
   / How much do you care about pre emissions #71
... and at least on my tractor, running it at PTO speed from time to time basically negates the need to regen. I just did a job that had me running near PTO speed for several hours, after weeks of running the thing at mostly idle. Dropped my soot level down 10% in just a few hours.
When it does regen, no big deal. If I'm going to have it running awhile anyway, I just let it do its thing while I keep running the machine. If I was planning on shutting down, I have the choice to delay regen until later, or just park it outside the barn for 20 - 40 minutes while it does a parked regen. Parked regen takes longer, but takes soot level all the way back to zero.
   / How much do you care about pre emissions #72
I dont think we have a pollution problem in the western world at this point. Air, water, even road side trash, is Way less than it was in late 80s/early 90s. I do think they keep trying to squeeze a tiny bit more (or less really) out of a shrinking pool.
In the 60s/70s were things out of control; yes! Did some regulations need to be placed, also yes. Have we gotten to the point that we have gotten to the 80% better, and them trying to squeeze the last 15-20% going to not worth the cost; IMO also yes.
Kinda like cars. Sure, we have gone from 12mpg being pretty normal for a 160hp truck, to 19-21 mpg being the norm for a half ton, making 420 hp, yep. Moving from 12 to 18; even at a 50% increase in cost, is worth it. Now, getting another 1-2 mpg, at another 50% increase in cost, definitely not.
I do know that after they closed the San Juan coal generating station in my state a few years ago, the regional haze that was infamously associated with the four corners area has disappeared.
   / How much do you care about pre emissions #73
And don't get started on the gases released from a volcanic eruption! Just one, one event outputs more the we do on a year!
Does it? Find some research done by some earth scientists on the topic, and post the links to their papers. IIRC only the few very largest eruptions over the last few hundred years emitted more than we do in a year now.
   / How much do you care about pre emissions #74
I disagree with that actually. Every state and municipality with emissions testing is sniffing your tailpipe and if you don't pass, you don't get your license plates renewed. Kalifornia is especially hard on that. So is Illinois.
Illinois? Maybe Chicago or suburbs but not where I live.
   / How much do you care about pre emissions #75
I disagree on the global warming issue, and it shows especially in Canada's northern boreal forest, with soaring record temperatures and regular large forest fires in places that haven't had fire like that before. Even the rise in house insurance pricing in Florida means the insurers can see that the historical averages for storms and storm severity are likely to increase their payouts.
I don't think we should go back to the horses and sailing ships tomorrow, but moving towards less greenhouse gases would be a good idea. Sure it will cost more than doing nothing, but we do only have one planet with all our eggs in one basket, so erring on the side of caution would be a good idea IMO.
   / How much do you care about pre emissions #76
I do agree the climate is changing, but please don’t use false examples. The North American boreal forests have evolved by periodic long interval large fires and regeneration. These events were historically very infrequent (every 200-300 years). but yes they did have high severity fires. These forests in North America are all very old and it’s time for renewal by fire. It goes in cycles that are hundreds of years apart.
   / How much do you care about pre emissions #77
I doubt the validity of this claim, but even if true, I don't see how it's relevant.
Knowing that one neighbor kid probably pees in your pool, do you tell all of the kids they can too? I mean, if one volcano is emitting greenhouse gasses, we might as well go whole-hog, and add to it as much as we can?
   / How much do you care about pre emissions #78
I just outlined how we are conflating pollution and climate.
They are two separate things. The drastic reduction in pollution is having zero effect on a climate that is always changing. Why is that?
   / How much do you care about pre emissions #79
Many scientists have been debating this determination for several decades, and still fail to reach a consensus. Who knew they could have all saved billions of dollars and millions of man-hours, and just asked you!?
   / How much do you care about pre emissions #80
I understand how common sense and logical conclusions drawn from readily available studies baffles a lot of people.
Have you not figured out, there is more money in the fear hustling of climate change then there is in the solation of climate change. Why solve it when we can debate for several decades at a cost of billions...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
