What class of tractor for maintaining two miles of road at higher elevation?
/ What class of tractor for maintaining two miles of road at higher elevation?
Thanks airbiscut. That DJ 5055E could be worth a look, but too many hours on the others, I think.
At this point I'd rather just spend the money to get something under 500 hours with the hope that it won't need much work other than regular maintenance. I've had bad experiences before buying older equipment (super high quality RV). You'd fix one thing and something else would break the next week. The engine and trans (Cummins/Allison) was solid, but everything else...
Funny, but I bought it off a old timer with a 15,000 acre farm. He gave us a tour of the place. Boy did he have a lot of $$$$$ JD gear to run that place.
[edit] looks like that JD 5055E is 2WD.
/ What class of tractor for maintaining two miles of road at higher elevation? #82
Thanks for keeping and eye out for me, but a cab is just something I'm not willing to compromise on. If I had a sealed shop that kept the slit out, then maybe, but my dirt floor barn does not do a good job and everything in there gets coated after the wind blows. If I have to clean it before I use it, I'm probably going to hate using it.
I didn't specifically mean that tractor, I was more pointing out that I was surprised to see one of the big 4, 105 HP, even if open station, at that price. And with that, maybe there are other New Holland Workmasters, closer to you, and spec'd flmore for your use, that would be in a reasonable price range.
/ What class of tractor for maintaining two miles of road at higher elevation? #83
...I have a 200+ acre ranch (6,800ft above sea level) with a few miles of single lane gravel road that needs to be maintained.
...Budget would be about $30-35K for a lightly used tractor with a loader and land plane etc. Might bump that up another $5-10K to get a cab (everything in my three sided barn gets coated in silt in the spring!).
...At this point I'd rather just spend the money to get something under 500 hours with the hope that it won't need much work other than regular maintenance.
Those two things are incompatible 🤔
/ What class of tractor for maintaining two miles of road at higher elevation? #84
Backing up a bit now... But my understanding is that there is two miles of road that needs year round attention. This road is wider than a single track, has turnouts, is in the mountains, and other people use and depend on the road as well - I believe you said 8 to 10 cars a day.
I wonder if a tractor is the right tool at all? Maybe a small road grader would be more suited to the job. Small towns & countys are always upgrading the fleets. Small governments are required to publically list equipment for sale & many post online. A friend here bought a road grader to work the roads on his cowboy ranch. It does the job nicely. He turned all his jeep trails into nice crowned roads with ditches and it didn't take long. A Galion 503 used is in the $10/20K range.
If we take away the requirement for a tractor to do road work - a job that tractors only do so-so anyway - it really opens up a wider market for a tractor to do everything else.
rScotty
Yeah, I know and that's why I posted earlier in the week that (after visiting some dealers) I was increasing my budget to $60K or 65K. Yes, I know I keep moving the goal posts. I really thought a budget option like a Mahindra/TYM/Branson would be appropriate, but the local dealer said they were having problems with the turbos at elevation and were having to de-rate the tractors HP to work around the problem.
The Kioti / LS / NH dealers are all too far away.
Massey utility tractors are made in Brazil not Japan.
The Deutz 4080 is not made in Europe, but "globally sourced". As far as I can tell the engine is a rebranded Farmall that's globally sourced.
John Deere have a good dealer network but are also globally sourced.
Kubota and Yanmar are the ONLY utility tractors that are made in first world countries. The Yanmar SM475 looks interesting, but it has a Deutz engine (is it a real German made Deutz engine, or just a re-badged Farmall?) Moot point as there are no close dealers anyway.
So that leaves Kubota. The dealer is 1/2 an hour away. They are made in Japan, and they are the most expensive tractors (go figure!).
I'd consider a higher hour tractor if I could see it in person, but there's nothing local, so it's either a brand new Kubota or a low hour unit off Tractorhouse, bought from 1/2 way across the country, sight unseen.
Maybe I'm over thinking this, but I want something to last me the next 20-25 years.
rScotty
You make a fair point, but I just feel like owning vintage machinery is not for me. I've watched videos and read blogs of people who bought vintage excavators to dig foundations or a pond etc, and they are three years into it, and are still trying to get their equipment running reliably.
/ What class of tractor for maintaining two miles of road at higher elevation? #87
Fair enough in your case. We bought a new top of the line Kubota ourselves.
But lots of people follow these discussings. Alternatives are fun, and also the mechical heads will never understand why "experienced" machinery is not as appealing as new.
It is worth mentioning that some entities like towns, school districts, fire depts, and county govenments tend to have maintenance departments and fund replacements out of grant money or taxes. They have no reason to mis-represent their used machines. In fact, there are legal reasons not to do so.
rScotty
/ What class of tractor for maintaining two miles of road at higher elevation? #88
/ What class of tractor for maintaining two miles of road at higher elevation? #89
/ What class of tractor for maintaining two miles of road at higher elevation? #90
/ What class of tractor for maintaining two miles of road at higher elevation? #91
/ What class of tractor for maintaining two miles of road at higher elevation? #92
/ What class of tractor for maintaining two miles of road at higher elevation? #93
/ What class of tractor for maintaining two miles of road at higher elevation? #94
NEW!
/ What class of tractor for maintaining two miles of road at higher elevation? #95
They are asking a pretty penny for those Kubotas. I've seen a few low hour (100-200h) M5-111's for $59-63K advertised on Tractor-house. Not sure if that's real or a dealer playing games, but that's the type of deal that would motivate me, provided the shipping to CO is reasonable. I need to make some calls.
I sat in the Deutz and it seems like a nice tractor and I was really thinking positive things (dealer said they could do at least $5K off). Then I got home and found out it's not a real Deutz. Maybe they're just fine, but I'd rather not take a chance just to save $10K over a Kubota.
Not interested in a JD either for the same reasons.
/ What class of tractor for maintaining two miles of road at higher elevation? #97
It's your money, and I'm not trying to twist your arm at all; but don't just assume Kubota is 100% made in Japan. Someone posted the info on where their engines, and other components are manufactered, including such 3rd world places as Thailand, Indonesia, and Illinois. There is not single source machines anywhere; even a Belarus-MTZ is gonna have a Korean starter, Chilean wiring harness, and Vietnamese tires.
/ What class of tractor for maintaining two miles of road at higher elevation? #98
Proof that there are machines within your new budget, in Kubota, that are low hour, and should meet your needs.
I'm not suggesting you drive to Micanpy FLa, just a sample of what's out there. 631 hours should be fine, and and 3 sets od remotes for hydro till/pivot rear blade, with an extra to spare for TnT
It's your money, and I'm not trying to twist your arm at all; but don't just assume Kubota is 100% made in Japan. Someone posted the info on where their engines, and other components are manufactered, including such 3rd world places as Thailand, Indonesia, and Illinois. There is not single source machines anywhere; even a Belarus-MTZ is gonna have a Korean starter, Chilean wiring harness, and Vietnamese tires.View attachment 1057381
That's interesting and food for thought. I'd assumed that if there's plaque on the frame that proudly states "MADE IN JAPAN", that would indicate that all major components were manufactured in, and sourced from Japan. I might have to dig a little deeper.
I'm not suggesting you drive to Micanpy FLa, just a sample of what's out there. 631 hours should be fine, and and 3 sets od remotes for hydro till/pivot rear blade, with an extra to spare for TnTView attachment 1057404
Not a bad deal at all. I've made a call on a M5-111 that is super low hours, but it's on hold, so probably already sold. I'll take a closer look at that m6, thanks.
[edit] Is that ad on facebook?
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2016 Ford F-550 Ext. Cab Enclosed Service Truck (A61573)
2016 Ford F-550...
PALLET OF TRAILER TAIL LIGHT (A64280)
PALLET OF TRAILER...
2011 Freightliner M2 106 Medium Duty T/A Dump Truck (A61573)
2011 Freightliner...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
UNUSED WOLVERINE HYD SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
