Fuel Filter TC45DA/ TC Series
/ Fuel Filter TC45DA/ TC Series #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
Today my TC45DA quit like it was out of fuel. I pulled the line from the tank off the filter and nothing run out. I used a compressor at the fuel cap and tried to get fuel to flow wi no luck. Then I blew from the line I took off the filter back to the tank and that got fuel flowing. So I must have junk inside the fuel tank that blocked the line.
With it running fine again I was watching the fuel filter to make sure it didn’t get blocked again. However, I noticed that fuel filter only was staying at about half full is that correct?
How much fuel is in your fuel filter when you’re running hard like heavy bush hogging?
/ Fuel Filter TC45DA/ TC Series #2
If you didn't bleed the fuel system after, I would do that.
The fuel filters on all of my diesels are full.
I was pulling a 9.5’ Woods C114 bushhog before and after the line plugged up and I cut at least five acres after that and it maintained that level of fuel in the filter that entire time.
I don’t think it needs bleeding based on how it ran afterwards which was the same as before the incident.
/ Fuel Filter TC45DA/ TC Series #4
Pinch off the vent line on the top of the filter base. See what that does for keeping the filter bowl full. Better yet, just snip the hose and put a plug of some sort in both open ends. If you notice an improvement I can explain why.
I’m all ears for the why!
/ Fuel Filter TC45DA/ TC Series #6
It's quite simply really. The vent line connects the top of the filter base to the injector return line with a free flow to the top of the fuel tank. The supply pump is pulling fuel from the bottom of the tank through the filter and pushing it to the injector pump. You already know you have (or had) a problem with fuel getting out of the tank and into the filter. Once that starts and the supply pump has trouble getting an adequate supply of fuel it will start pulling air from the vent line and the filter won't stay full.
Thanks
I saw that in this previous thread.
I’ll try clamping off the vent line that exits the top of the fuel filter.
I wonder if a 3/16” fuel line shutoff valve would work to stop flow of air from the vent line?
I’m also thinking about putting a shutoff valve on the supply line from the tank so that when I unplug it I don’t lose so much diesel.
/ Fuel Filter TC45DA/ TC Series #9
Waste of money. I just use a piece of scrap 3/16 rod, like from an old battery hold down J bolt, cut off two pieces about an inch long and stuff that into the hose.
I cut and blocked off the line that goes from the top of the fuel filter and tees into the return line. It runs great and the filter bowl stays full now.
Question what size is the main fuel supply line from tank to filter highlighted in the attached picture.
I want to put a shutoff valve in that line.
Also where does that line connect directly to the fuel tank and is it that connection point accessible?
/ Fuel Filter TC45DA/ TC Series #13
If I were you, I'd do 2 things. One, I'd install a strainer in the filler pipe (Kubota sells them btw) and they are cheap and 2, I'd install a Racor fuel polishing filter between the tank and the existing fuel bowl on the tractor.
Good idea.
Do you have a part number for the Kubota strainer?
I have a Racor 445 30 micron filter on my diesel storage tank.
I am not familiar with a fuel polishing filter got a link to one?
/ Fuel Filter TC45DA/ TC Series #15
Good idea.
You have one on your bulk tank, I run them on my tractors. I use the IFJF bases (lots cheaper) and the Racor elements spin right on. In fact I like the IFJF bases better because there are 2 inlets and 2 outlets in each base and instead of 50 bucks, they are 20 bucks. Just installed one on my F2880 mower 2 micron Racor filter element.
/ Fuel Filter TC45DA/ TC Series #16
Every Kubota dealer stocks them I believe they are around 10 bucks and drop right in. You'd be amazed what they catch too. I get grass, bugs and small twigs and I bulk fill as well. All that stuff migrates to the bottom of your fuel tank and eventually blocks the fuel flow. Kubota used to supply them with every new tractor. Must have gotten cheap. Fit right in the filler neck and come with various size bases so one size fits all.
Well it’s still running great at PTO and any rpm above idle. It runs my 9.5’ mower and 74” flail mower great.
However, it’s surging at idle.
What would cause it to surge while idling?
I am planning on trying to clean out the tractor’s fuel tank this winter. I may also check/replace the fuel return lines.
/ Fuel Filter TC45DA/ TC Series #18
Nice thing about both my tractors is, there is a drain bung on the bottom of both saddle tanks so if I want to drain them and get out any debris, simple matter of letting the fuel get down low and taking out the drain plug.
/ Fuel Filter TC45DA/ TC Series #19
Fuel starvation. Don’t hit these tanks with compressed air. These engines use a diaphragm lift pump and over pressuring could damage it. My tank was full of garbage in the bottom. These tanks have a very small inlet and it easily can plug. I drained the fuel and just used a hose taped to a shop vac to vacuum the tank clean. Then a little flush to clear the lines.
Since then mine only surges lightly on first cold start. After it does not. I ran into the fuel bowl half full issues. After cleaning the tank and a new filter it stays full.
Since the supply line from tank to filter was disconnected when I used a 18 volt tire inflator it would not have damaged the lift pump.
I can fully believe that junk in the tank would cause it.
The hose on a vacuum is a great idea thanks.
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2019 JOHN DEERE 30G EXCAVATOR (A65056)
2019 JOHN DEERE...
2018 GENERAC MOBILE PRODUCTS MTL6S (A67714)
2018 GENERAC...
8ft Fork Extensions (A66734)
8ft Fork...
2018 MAGUNS  VACUUM/POWER WASHER TRAILER (A67714)
2018 MAGUNS...
3268 (A63117)
3268 (A63117)
