BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,410
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
UPS dropped the heads and gaskets off today, so I got started putting it back together. The AFR heads are really nice pieces of equipment, and although they are an as-cast head, the unmachined cast surfaces are pretty smooth. The water passage that was the problem on the Procomp heads is properly located, but I forgot to get a picture of them.
I applied sealant to the head studs and installed them in the block. This is messy, as some of the sealant always ends up on the block deck, and it's a pain to get it all wiped off. Sliding the head gasket down over the studs is a fiddly process, but you can't really put it on first because of the thread sealant mess. The heads slid part way down, as is usual when using studs, but some gentle work with a dead blow hammer got them seated all the way down.
The stud's threads and nuts have to have a coating of ARP lube, which is a bigger mess than the sealant, just as bad as never seize, but black.
After snugging them up, I torqued the nuts to 30 ft lbs, 50 ft lbs and final torque of 70 ft lbs.
I still have to align the pushrod guide plates and torque the rocker studs, but at least the heads are back on.
One other thing different on these heads that the plugs are set in the head at an angle, leaning them away from the header pipes, which will help keep from burning plug boots.
