LS MT225S - Chainsaw scabbard
/ LS MT225S - Chainsaw scabbard #21
Most of the time you put the scabbard where you can with few choices and lots of trade-offs. I was lucky with my M5640 and had a place behind the FEL tower so it didn't stick out to catch on stuff or obstruct view and wasn't in the way getting on and off the tractor. Plus easy to reach standing on the ground.
gg
/ LS MT225S - Chainsaw scabbard #22
I guess if you are going to forget what you have in the belly of your bucket or the jaws of your grapple - better not use that option.
/ LS MT225S - Chainsaw scabbard #23
I know it is more work, but everyone has the space on top of the hood for storage. My removable box tends to get filled up with chains and miscellaneous tools. The frame hinges open when it comes time to fuel up.
/ LS MT225S - Chainsaw scabbard #24
Wouldn't do that with the Green plastic..😁
/ LS MT225S - Chainsaw scabbard #25
It is more important with the green plastic. Keeps anything from hitting the hood.
That said, I went 18 years with this tractor and my homemade steel front protector before I hit a 2" branch just right, so that it punctured the plastic part of my Kioti's grille.
/ LS MT225S - Chainsaw scabbard #26
I just made one out of some left over hickory flooring I had. Had to tilt it a bit saw my 25” bar cleared the tire by a good margin.
Great idea using hardwood! Nice work too!
/ LS MT225S - Chainsaw scabbard #29
Yes it's q 4" square post cut in half. I had a small chunk left over from a project.
Thanks. Was looking at some I had here and wondering how hard it would be to heat and reshape it..
/ LS MT225S - Chainsaw scabbard #30
If it is PVC, it is easy to bend up if you are patient. For conduit, I use a hand torch, but for something that big, consider rigging up a water trough that you can heat up and submerse. Not sure if 212F is warm enough; others here may know.
If your wife lets you, toss it in the oven for 10 minutes at 300 degrees. It will be soft and pliable until is starts to cool off. Wear gloves and work fast. Good luck.
/ LS MT225S - Chainsaw scabbard #32
That'll work. Plus, have a helper who can spray some water on the hot PVC as you hold it with gloves in the shape you want. Or a very wet rag.
Remounted the quick-draw chainsaw scabbard on my ROPS. This is the best location for it yet.
Go back and read post #4....
Hi, Sure did. This post was for the first one I made that I removed. After using it I preferred to use the lager one with the blue frame in the same location. This one was made from PVC square tube and the blue framed one is made of HDPE.
