Max 25 HST FLUID
/ Max 25 HST FLUID #1
garye5007
Member
Glastonbury, Ct
Mahindra Max 25
Hi, I need to top off my hydraulic transmission fluid in my Mahindra max 25 HST and I was wondering if this fluid is OK to use. Thanks! IMG_2246.jpeg
/ Max 25 HST FLUID #2
Don't know about the Traveller premium you posted, but I hope this may help you or someone else.
CARQUEST 760-01 tractor fluid.
it has the same spec as Mahindra Universal Hydraulic oil and the same verbage is on the label of the Mahindra oil and the Carquest oil. This leads me to believe they are either made at the same facility or just by "coincidence" are the exact same specification.
I use the Carquest oil in my tractor and know several Mahindra tractor dealers that sell it.
/ Max 25 HST FLUID #5
i refilled my tractor with that about 200 hours ago without issue
/ Max 25 HST FLUID #6
The book says API-GL-4, gear oil, 80W...Is this the same stuff? All I can find is 80-90 GL-5.
/ Max 25 HST FLUID #10
You have an HST and the manual says to use regular gear oil?
Or is it for the front axle, not the transmission?
It's HST, forward and backward pedal. This is why I'm confused. Thank you for helping by the way. I recently bought this and theres no fluid on the sightglass, I need to add or change it.
/ Max 25 HST FLUID #11
Well, now there's two of us that are confused. I don't even understand why they want GL-4 in the axle instead of GL-5.
Anyway, take a whiff of what's in there now. Gear oil smells nothing like hydraulic fluid.
/ Max 25 HST FLUID #12
I did add a couple more pictures, It does say the transmission is hydraulic+mechanical.
/ Max 25 HST FLUID #13
i just used the same fluid in the axle, it differs over the years based on the manuals
/ Max 25 HST FLUID #14
I used the same stuff in OP's pic. Never saw it in the sight glass and ended up overfilling it, I put in about 3 gallons of fluid. Do you know about how much extra these things hold? thanks
/ Max 25 HST FLUID #15
be careful, emax and max are 2 completely different machines, I can't speak to the emax.
/ Max 25 HST FLUID #16
FWIW, check your Hyd level before adding more. Mine was filled above the sight glass, and because Hyd fluid is relatively clear, it looked like it didn't have any fluid in the sight glass. If you don't have a dipstick on your reservoir, make your own with a long zip tie. Measure down from the fill port to the site glass, and then mark the zip tie accordingly. Will get you very close to the actual level of your fluid.
Zero Turn Mower (A59231)
Zero Turn Mower...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
UNUSED WOLVERINE HYD SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
Caterpillar Articulated Truck Parts and Service Manuals (A63117)
Caterpillar...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
