Generac or Koehler whole house generator?
/ Generac or Koehler whole house generator? #22
I wanted a generator to power my 400A service for the house and the barn. Estimate based on whole load coverage was $65K installed with an 80 Kw Generac, transfer switch, wiring, and concrete pads for generator and propane tank. Generator alone was $36K. Going with the hay barn project instead.
/ Generac or Koehler whole house generator? #23
Generac is the top, widely available generator company. As with tractors, there probably isn't a huge difference.
From what I have seen, it will cost about the same to have the generator installed as it will to buy it. I'm looking at the 22kwh dual fuel (propane and diesel) option. I think it was about 10k, but the guys in Tyler wanted another 10k to install.
I haven't priced anything, but that seems kind of extreme to have them install it. Thanks for sharing, it makes me think it's something I'll have to figure out how to install myself.
/ Generac or Koehler whole house generator? #24
Installation is fairly simplistic. Remove the utility feed from your panel. Connect utility feed to the Transfer Switch. Connect the Transfer Switch to the Panel. Connect the Generator to the Transfer Switch. Connect Fuel to Generator.
I paid $15.8K for the Generator and electrical work and an additional $1500 for propane plumbing. One other consideration is the Fuel regulator need to be matched to the generator fuel requirements. I ended up with multiple regulators.
What could be done to reduce installation costs would be set the generator on the pad, mount the transfer switch, run the wiring from generator to transfer switch and panel. Then have an electrician do the final hookup.
Same could be done for the fuel source. Run the lines and have a qualified gas plumber do the hookups.
We were required to get a Permit and County inspection for the installation.
/ Generac or Koehler whole house generator? #25
Would be far cheaper to have the electric company install a second meter at the barn to attach to your service box. Even if you have 2 different bills each month. I did that once. To save the cost of running drop poles and lines from the house service to the barn.
/ Generac or Koehler whole house generator? #26
Propane heat. Yes have A/C but have had backup generators for decades years so know the drill and know how to juggle things. My issue would really be the surge to start things. The motivation is advancing age.
My electrician is a friend and this is a close rural community where people take care of others. I would have him "service" the unit but I would change the oil and that sort of thing and would count on him to maintain the electrical aspect. I don't see a problem with that but just as a hedge hope I can retain my 10K/12K plug-in generator as a redundancy. It plugs into a receptacle outside and we flip a switch in the basement to run various circuits.
Someone needs to invent a box that goes in the garage and safely stores a week worth of energy to run things in a short-term emergency. The Tesla battery is pretty close but they need to figure out the safety aspect of the things so it won't burst onto flames or whatever..
It sounds like a great plan to have your electrician take care of things, and it sounds like you know the generator drill, which are both great. Variable/inverter AC units have lower starting draw that helps generator use. You can get your electrician friend to put on a soft start to ease the surge, but not all AC units are compatible. Don't put on a hard start as that makes the starting surge worse.
I never thought of the liquid cooled vs air cooled thing. My lawnmower is diesel cooled because I want the longevity and quality that goes into a liquid cooled, which implies commercial application while an air cooled consumer model leads me to think lesser quality and maybe not there when you need it.
I'm very appreciative to be able to discuss this with a group like this that has accumulated knowledge and experience on generators. Every post has something useful and lots of things brought up that most of us don't immediately think of. 🍻
I think ten years ago there was a big gap between air cooled and liquid cooled generators, but I think that Generac and others have realized that they were taking a hit because of the reputation for poor longevity of their air cooled units. (No idea if it is / was true.) I would comment that Caterpillar/Cummins purpose built a new 1l air cooled engine for generator use, and designed it to use synthetic oil that helps it live longer in high heat, high load home usage. That said, I went for diesel, because I have it for the ranch anyway.
We have solar and Tesla Powerwall 2s. The Powerwalls are mounted several feet from the house on a concrete wall. If they catch fire, it wouldn't be great, but it would be much better than on the house or in a garage. I've seen folks plant roses or shrubs in front of the Powerwalls so you don't have to look at them. I think wall mounting away from a building would be prudent for most battery systems. The newer Powerwall 3s are supposedly lithium phosphate and therefore a lower fire risk, but energy is energy in my book. The upside to Tesla is that they have a gizillion miles of experience with their battery systems, but the downside to Tesla is that they are constantly tweaking the software and the updates aren't always bug free.
At this point, I would consider any of the major battery brands, but make sure that you put enough in. ACs use a fair bit of energy.
All the best,
Peter
/ Generac or Koehler whole house generator? #27
If you use a propane generator, consider the size of your propane tank. At full load, a 22K model will use a lot of fuel.
My neighbor found that out the hard way. During the last 7 day outage we had, he drained his 400gal tank in a little over 4 days.
Not a problem if your average outage is only a few hours, but something to think about.
/ Generac or Koehler whole house generator? #28
Great point! It happened here to some folks that I know.
Something to be aware of some insurance companies and jurisdictions have rules around larger propane tanks, e.g. 1,000 gallon and up. It is one of the reasons why I went with diesel.
All the best,
Peter
/ Generac or Koehler whole house generator? #29
All the best,
Peter
My main genny is diesel also. I fuel it from my 1000 gal fuel oil tank. I keep it topped off during storm season and it would run the generator for a month if necessary.
/ Generac or Koehler whole house generator? #30
The problem becomes when one defines "a week worth of energy " "things" and "emergency".
My last long power outage was probably Hurricane Isabel in 2003. We just hunkered down, lived more in the basement (cool). Didn't have a generator. Power was only out for a few days for me and the family (6 people).
If you never want to lose power again, buy a generator. lol
And that's what happened to me. After Isabel I bought a 7K generator at HD for ~$600 w/ Honda engine. I try to run it a couple of times a year. Have not needed it since 2003.
My best power purchase was a DEWALT 1800 Watt Portable Power Station and 20V/60V MAX Lithium-Ion Battery Charger, for ~ $200 years ago. I'll slide 4 batteries in to it, I can run my networking and lights off it for many hours.
/ Generac or Koehler whole house generator? #31
Wow you guys sure do need the big stuff . I thought that emergency meant doing without or definitely less. I know you farmers need a large rig to run your needed operations .
Most folks up north here just keep a 5000 -7000 unit and do well with them. I had a 3200 GENERAC myself and still do though it’s a tad small. Recently I got a 17000 GENERAC from a guy who lives in the deep woods and wanted newer better. So I grabbed it for $100 with 200 hours on it. One thing I’ll say is wow it’s HEAVY and huge. It’s so big I can lay a piece of plywood on it and use it for a bench and weighs like a Harley. When we set it in the F 150 it actually dropped and could feel it back there driving home. As for being so called portable …..it ain’t really .
Mine range fine testing it and I know the guy so no concerned he’s ripping me off. I fire it up a couple weeks later ran it and shut it off. Now I always leave the carb dry if possible for well known reasons. Soooo me turns off the fuel and let it die which it did with a backfire. Yes it has the antibackfire solenoid on the Nikki carb same as on your Briggs mowers. Next month tried to start , nothin. Check around seems no spark , weak spark not sure really. As feared it must have sheared the flywheel key.
Now to get to the flywheel is a true adventure. Just taking the shroud off required everything off the front from the panel past the carb, intake. It sounds easy but it wasn’t. The panel really couldn’t be unhooked due to the way it was wired and and it stayed in the way most of the time. Finally I get to the flywheel and it looked fine but possibly had moved so I had to go bum a massive puller as mines smaller. It came off with the usual tapping and big bang . What do I see but the key is intact but seems a bit smeared. Put flyeel back onpart way and it’s obvious that it was a loose shallow fit and the kerf had just ridden over it. All that for a poorly fitted key. I took the next size up from hardware store and teased it down for a nice tight full fit. Together it goes , another battle with the shroud and panel cleaning out the carb along the way and it runs fine. I’m thinking the flywheel had already started moving which caused the violent backfire I’d seen.
Lesson learned, these things aren’t fun to work on at all. Everything is layered onto other things . If I was in a place where I needed one badly I’d want to stick a propane conversion on there and be safe from the dreaded Nikki carb hassles I know so well from my mower, same exact carb. The carb itself is easy but you have :)unlike my mower ) to yank all that crap off to get to it. So do avoid if possible the Nikki nightmare with these especially if you are stuck with Booze-Gas . Store that carb dry or better use propane. One more think on Nikki. Those EBay rebuild kits and cheap toss on replacement carbs we all love ain’t so with Nikki. They either don’t have what you need or don’t exactly fit ( been there done that with mower ) . The toss ones you will notice aren’t well reviewed and look how few the selling company has sold, the bad comments ect. It took 3 orders to fix my mower becuse the tiny O rings are not in the kits and those are the usual culprit. Soooo if you do have to tear down ol Nikki do yourself a favor and spring for the OEM kit. It’s worth it in time and hassle.
/ Generac or Koehler whole house generator? #32
The barn is on a separate disconnect from the meter, 225A to the house, 175A to the barn. I am all electric. According to the calculations 40Kw is for electric heat in the house, plus we have a 12,000 BTU mini-split in the barn tack room to keep the pipes from freezing. During the deep freeze in 2022 the wife had to haul water to the barn to water the horses when we lost power for 3 days. Trying to avoid that in our old age.
/ Generac or Koehler whole house generator? #33
With what we want to power, we need a 22kW machine. Per the spec sheet, the machine consumes about 2.35 gph of propane at 1/2 load and 3.75 gph at full load.
Based on my electric bills for the last 12 months, my average power consumption is less than 3.5 kWh per hour.
Generac does not provide any info on fuel consumption at that load.
/ Generac or Koehler whole house generator? #34
We installed a 22kw Honeywell (Generac) 8 years back, no problems. We sized the unit based on start current for a 5 ton heat pump. Normal average use for us is about 2kw/hr. Guesstimated consumption at that level is 1.2 - 1.5 gph. Arrived at that by graphing out the published consumption points & finding 2kw on the line. FWIW, no load consumption is about a gallon an hour accordingl to the graph.
/ Generac or Koehler whole house generator? #35
Many (most?) propane generators that I have been around, don't throttle back much from 50%. They have to keep the speed up for the AC frequency, and below a certain concentration the propane (or gas) doesn't ignite.
Diesel tend to use less fuel at lighter loads, but you run a serious risk of carbon deposits, aka "wet stacking". If you do run a diesel often at lighter loads, I would suggest that do it and yourself a favor and run it for a couple of hours occasionally into a load bank that will drive it to 100% load. An old range or two works well for many folks. I have a cheap space heater that is 100% load. (Yes, it is a big space heater. ;))
All the best,
Peter
/ Generac or Koehler whole house generator? #36
My 20kw diesel uses about a half gallon per hour. This was only 1 part of my fuel of choice decision. The others are;
In a long weather related outage you can't run out and fill up a bunch of 5 gallon tanks to dump into your propane genny and the propane company will be swamped even if there drivers are able to make it to work.
Never seen a propane co. that wasn't trying to ###k me over.
I always have about 1000g of diesel on hand (especially in the winter) between 3 or 4 tanks.
A diesel engine is perfectly happy running "24-7"
My needs (concerning an outage) are not by any means you're average suburban homeowners needs where the convenient "generac type propane pkg" is an ideal solution. 👍
/ Generac or Koehler whole house generator? #37
Been awhile since I looked at the generator market. Running rpm’s have a large impact on fuel usage. Some diesel gensets run at 1800 rpm, I think all the propane units are in the 2800-3600 range.
/ Generac or Koehler whole house generator? #38
I installed my second cummins generator for my personal use(sold previous house). They work great. The transfer switch is so fast most of the lights dont even go out. I would buy a third without question!
/ Generac or Koehler whole house generator? #39
Although I have a few generators, I MUCH prefer to power my whole house generator with my diesel tractor.
I always have it ready to go and if you want, you can park your pto generator near the house in a little house, just like you would have a stationary generator.
It's been working for me for many years now, so I have no plans to change.
SR
/ Generac or Koehler whole house generator? #40
Ah, another generator thread. There is no one best answer. The very first decision point would be frequency of power outage and length of average outage. If you experience alot of long outages, go liquid cooled, 1800 rpm.
If you rarely get alot of outages that are very long in length, go air cooled 3600 rpm.
On average liquid cooled costs about double the price of same KW output machine. Installation is only slightly more than air cooled. Diesel generators are fantastic units, but be prepared for real expensive cost on repairs if anything goes wrong. On these units generally you need industrial trained technicians to work on them ( i dont work on diesel units).
Air cooled units are far cheaper to maintain in low hour outages. An air cooled unit is kinda like a large lawn motor engine. The liquid cooled units are like a complicated car. Prices for liquid cooled repairs add up very fast.
I service about 300 air cooled customers, and only 3 liquid cooled clients. All generac units, as i no longer work on onan, Cummins or kohler. Not that there bad units, but i dont want to stock parts for 4 different brands. Stocking inventory for just Generac costs alot.
As far as reliability of Generac generators…..i have very few major issues and i have never had generac not honor a warranty repair. I find that any unit produced after about 2012 to be VERY solid and reliable (older units do have alot more issues). I have several customers with over 2,000 running hours on their machines. With proper maintenance they prove very reliable. Most of my customers are in the 200-300 hour range though.
My own 22 kw home unit (3600 rpm) is 8 years and only has 119 hours. The unit I resurrected from a lightning strike (2008 10 kw) has 518 hours when i repaired it. This was a complete wreck. All control wiring melted into a bundle of wires. Owner wanted newer, larger unit. I was in the process of demolishing this old unit when i decided to try and fix it as a winter project. Now it sits behind my shop and is configured for manual start and manual transfer to shop. It works great once more.
As for fuel loads, generac charts are misleading. I happen to have the opportunity to have use of a wifi recording fuel monitor attached to my unit during a summer storm power loss. Generally, i would manually shut down my generator during what was expected to be a multi day outage, during the middle of a warm, summer day. But the wife had 6 friends over during a quilting club get together. So i let it run and power house and barn. While entire basement was in use with a 5 ton ac load to boot, meter showed only 1.2 GPH average load. Meter showed highest load when ac fired up, and dropped drastically when ac shut down.
If it was a winter night power outage, it could have been up to 3 GPH propane use as i have 6 stock tank heaters running, heat tape, heated steps, etc. heat load is the most expensive loads to run. My house is propane and wood heat, propane water heater and propane cooking appliances. I have a 1000 gallon underground propane tank.
I also manually shut my unit down when its bedtime. I personally dont want to waste the fuel. All freezers and refers will maintain cold temp overnight. If its below freezing, i will restart unit after 4 hours off to maintain water troughs though, to keep from freezing over.
I have lots of customers that want there units to run the entire outage though, mostly people on medical devices. The only caveat is i recommend they shut down and check oil every day on air cooled.
3PT 2 Row Cultivator (A60463)
3PT 2 Row...
2020 DRAGON ESP...
PREVIEW DATES AND TIMES (A61166)
PREVIEW DATES AND...
2006 TerraGator 8104 (A61307)
2006 TerraGator...
2017 Nissan Altima 4 door (A61307)
2017 Nissan Altima...
KJ K1522 Portable Restroom 1 Shower & Sink (A60463)
KJ K1522 Portable...
