TM1820 Starter circuit
/ TM1820 Starter circuit
Is there a reason to think that this particular starter solenoid would draw less than 25A? i.e. Have you measured the draw? A a rule, at least in my experience, starter solenoids aren't particularly frugal devices.
All the best,
Peter
Clean wire from teminal C on the ignition switch direct to the S terminal on the solenoid.
Turn key: fuse blows.
Found a 40AMP slow blow MAXI fuse & connected that in place of the fuse.
I dug out an old ammeter from a box in the garage where it has sat for about 40 years Connected it in place of the fuse. Pulled out stop cable. Turned key - starter turned over normally, ammeter showed 40+amps dropping to 30ish amps while starter turning normally! I'm flabbergasted! There's perhaps a current spike for the pull-in coil to be expected momentarily (thats "FOR a moment" in English rather than "IN a moment" in American!) but 30Amps continuous for a little hold-in coil is ridiculous. There's clearly a starter solenoid fault going on here.
I want to use the tractor today to clear some garden rubbish for the missus & transport it to the firepile (I have a transit box (carry-all in US I believe) which will be just the job for this little beaut.
I'll refit the push button for now & start looking for the right solenoid to order.
/ TM1820 Starter circuit #23
Congratulations on tracking the problem down! Great job. Did you try measuring battery to new wire to solenoid, just to rule out the switch?
It is not uncommon for solenoid windings to partially short and that greatly enhances the current draw.
All the best,
Peter
/ TM1820 Starter circuit #24
I made mention to test the old solenoid type start for load. Best to replace it with the modern OSGR starter, they draw less power and crank over better.
Here is what a modern OSGR starter is all about.
And the best part is, OSGR last longer and are 2/3rds the price of a solenoid type. Check this out!
Your Yanmar OE p/n is 124250-77012
I think you're finally catching on here. That fuse had no business being there from the start. Whoever put it there didn't know what he was doing.
Ah! I thought the cable connectors looked "factory" to me & I've now found that , although not shown on the wiring diagram, there IS a "fusible link" factory fitted in there.
Presumably this had failed at some stage & been replaced by a standard blade fuse.
/ TM1820 Starter circuit #26
Not exactly the same thing is it? Some tractors use a standard automotive type slow blow fuse in that spot but it's much heavier than a simple blade fuse. They can be rated for as high as 80 or more amps. That type will support the starter energize circuit.
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
Farm Hand Silage Wagon (A65640)
Farm Hand Silage...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
