Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #1,381
Added a 15GPM filter, grease fitting to thumb mount and cut and re-welded thumb bracket. Really dumb design not allowing the thumb to go further back in the up open position. I was able to get about 6 more inches which helps for fully extended digging. Also added square stock between the thumb to keep it from getting mangled again hopefully. 13 hours on the new machine without issue. It does however really heat the oil up over 180F with a lot of dozing even with a cooler and fan.
   / Importing and modifying a new mini excavator from China #1,382
Mine came with a fan/oil cooler too, it wasn’t enough. I added a 7” fan, this helped, but still too much heat in my opinion in the engine compartment. I added an exhaust extension, as the muffler exhaust was just pointed to the engine cover opening. I think this helped too, but it’s not shedding heat like I’d like it to. Maybe a muffler that is outside of the engine compartment…?
   / Importing and modifying a new mini excavator from China #1,383
My fan setup is factory pulling then auxiliary one I added pushing out, lots of heat blowing out. Just curious if others with two fans run them as I have. I should probably get a thermometer and try some real world testing.
   / Importing and modifying a new mini excavator from China #1,384
I wrapped my muffler with ceramic then aluminized wrap which helped keep the heat from the exhaust down. Digging it seemed like my hydro oil was only hitting 120 when it was in the 80s out, so not bad until you work the drive motors a lot.
   / Importing and modifying a new mini excavator from China #1,385
Mine came with an exhaust heat cover/blanket, but I really don’t understand why no exhaust extension.
   / Importing and modifying a new mini excavator from China #1,386
Mine did come with the extension screwed into the exhaust shield. At least they are making improvements.
   / Importing and modifying a new mini excavator from China #1,387
on the L12 where the hoses come out of the boom, really sharp edges. took die grinder & rounded them off. replaced damaged hose protector.
almost ready to start using this dang thing.
   / Importing and modifying a new mini excavator from China #1,388
made ripper. works ok. may cut shorter & sharpen it more.
   / Importing and modifying a new mini excavator from China #1,389
Well I guess I did it again, Anyone know the Origins of Machpro Branded Chinese Hoes?
  • Good Post
Reactions: 1hp
Well I guess I did it again...
Congrats. So, maybe 4 1/2 metric tons? Maybe take it by the truck scales when headed home with it.
Can't wait til you open it up to see how its made....
1634 (A58375)
1634 (A58375)
2020 DRAGON ESP...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
