Harbor Freight Liquid Transfer Pump (Stick) failures
/ Harbor Freight Liquid Transfer Pump (Stick) failures #1
JCoastie
Coastal AL
LS MT240HE
I have the worst experience with these things. I've probably had 6 or 8 in the last 4 years. I never even have to change the batteries in them before they fail.
Is there a more reliable option?
I store 20 gallons of diesel and 20 gallons of gasoline all in 5 gallon cans, and I fill my equipment 5 gallons at a time (1 can), so I don't need anything large or elaborate, just something reliable.
I filled the mower this morning with gasoline which worked fine, set the pump aside to drain while I got the 5 gal can of diesel for the tractor, about 5 minutes, and the pump completely died in those 5 minutes. I checked the batteries, they were fine (1.46v) and I changed them just to be sure, nadda, dead! I use Energizer batteries.
Any options?
Junk
/ Harbor Freight Liquid Transfer Pump (Stick) failures #5
Any options?
Junk
I buy mine at Walmart. Probably the same as HF, but not a 40 mile round trip. Usually, the impeller comes loose. Clean it up and super glue or JB Weld will fix it. If not, they don't cost much and save work and spillage.
I'll check Walmart, thanks, didn't know they had them
/ Harbor Freight Liquid Transfer Pump (Stick) failures #7
@AaronD81 does it HAVE to be screwed on to the can, or can it sit on top and still function without making a seal?
/ Harbor Freight Liquid Transfer Pump (Stick) failures #11
agreed, can you link me to a Made in USA version?
I’d doubt anything like that is made in USA anymore. Can you set cans on a high shelf, then fuel by gravity?
/ Harbor Freight Liquid Transfer Pump (Stick) failures #13
Got a link to a good version of this type pump?
Nope...lol I buy a couple at a time myself when on sale in the ITC section. One thing I do is I use rechargeable Li-Ion batteries in mine, have a couple pair at all times. The bottom contact gets wonky and you need to reach in there with a long pair of hemostats or long handled needle nose pliers and pull it up a tad.
Northern has the same pump for 2 times the price. I'll stick with the cheapo HF ones, thank you. I have a couple of those new and funky no spill gas cans that spill constantly so I use the pumps instead. What a terrible design they are. PITA to fill and even more of a PITA to empty.
/ Harbor Freight Liquid Transfer Pump (Stick) failures #14
Any options?
Junk
Any options?
Junk
Useless cheap product that is temporary. Accept it and avoid wasting your money.
/ Harbor Freight Liquid Transfer Pump (Stick) failures #15
Any options?
Junk
Your not the only one. I have went through 4 in the 5 years that I have had my tractor. Gotta be a better,economical way.
/ Harbor Freight Liquid Transfer Pump (Stick) failures #16
Same story but I got mine on Amazon. Three pumps and none lasted more than a year of light use.
I have a decent pump for diesel fuel transfer similar to what is posted in post #10 that has lasted four years but it will not do gasoline. It is too cumbersome for 5 gal jugs but I have it mounted on the frame that holds a 50 gal reefer fuel tank that was salvaged.
/ Harbor Freight Liquid Transfer Pump (Stick) failures #17
I store in 5 gallon cans myself and have for years. I don't understand the need for a pump. I just pickup the can and fill the tank. Even the chinese cans work, but my leak a little around the seal.
/ Harbor Freight Liquid Transfer Pump (Stick) failures #18
^if you have 5 gallon cans that actually flow well, it's less of a problem than the newer EPA mandated cans that take forever to pour gas because of not being vented and having spouts that don't allow the fuel to flow freely. It also makes a big difference where your fuel fill is located. Lifting a can to fill on top of a tall tractor hood is a pain.
/ Harbor Freight Liquid Transfer Pump (Stick) failures #19
Any options?
Junk
Fill-Rite
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2004 Quick Draw Cover Trailer (A64047)
2004 Quick Draw...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63118)
Neckover GL24-2-7K...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
Three (3) John Deere 6000-Series Hood Guards (A63116)
Three (3) John...
