Old rotary cutter, tail wheel assembly?
   / Old rotary cutter, tail wheel assembly? #11
Without seeing it up close and measuring, my approach would be to find a bushing with an OD to go the whole way through the tail wheel socket with an ID that matches an assembly from High Grade. Then I'd weld the bushing in and tap it for a grease zerk. Adjustable height would be via spacers as found on RFM's.
Edited to correct to OD. Ought to proofread better:)
   / Old rotary cutter, tail wheel assembly? #12
The reason that tail wheel has a long shank (and lots of spacers) is that the rear mounting bracket is rigid. Newer rough cut mowers have a height adjustable mounting bracket.
   / Old rotary cutter, tail wheel assembly? #13
   / Old rotary cutter, tail wheel assembly? #14
That is a real simple fix. The tail wheel and fork assembly should be available online. That neck can be easily sleeved and welded, and reuse the fork even if the stem is not badly worn.
   / Old rotary cutter, tail wheel assembly? #15
I'm not a welder so that would not be a "real simple fix".
   / Old rotary cutter, tail wheel assembly? #16
Have you thought of paying someone or bartering with someone to fix it? The real simple fix is it might only cost you two chickens and not a whole flock, ;)
   / Old rotary cutter, tail wheel assembly? #17
What might be even easier, you may only need to replace the bushings or bearings for the stem.
   / Old rotary cutter, tail wheel assembly? #18
Should be a welding shop near by that could fix it especially if you get the parts needed for a repair.
   / Old rotary cutter, tail wheel assembly? #19
Could be a shredder by Servis Corp.
That looks like it. I don't see any parts just yet. I will probably have to MacGyver something together.
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2020 Bobcat T550 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T550...
Kubota BX25D (A53317)
2017 Ford Fusion S Sedan (A55853)
2017 Ford Fusion S...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2018 Ford Transit 250 Cargo Van (A55852)
2018 Ford Transit...
