Old rotary cutter, tail wheel assembly?
   / Old rotary cutter, tail wheel assembly? #1
LittleBittyBigJohn
Central Arkansas
John Deere 1025R, Kubota ZD1211
This is my father in law's. I have been trying to keep up his place and it's gotten to the point that it's really difficult to use it like this. How would I go about finding parts for it. The biggest need is the whole tail wheel/yoke assembly.
   / Old rotary cutter, tail wheel assembly? #2
If you don't see the assembly or parts you need, call their customer service. I've bought 5 wheels from them this year.......their customer service is good.
   / Old rotary cutter, tail wheel assembly? #3
Yes, another recommendation for High Grade Mfg.
I bought 4 caster wheels for my finish mower from them.
   / Old rotary cutter, tail wheel assembly? #4
That's an odd set up. What is the diameter of the shank?
Whatever you buy, you will probably have to weld an extension on to it (standard shanks are 5"-6"long and generally 1 1/4" in diameter).
Yeah it's a monster. I wish I knew the manufacturer, but any info that would have been on it has probably been worn off for 40 years. I'll measure it all up next time I'm over there.
   / Old rotary cutter, tail wheel assembly? #6
It's at the bottom of the adjustment pins so a replacement shank may work without modification. I'd guess 1 1/2" shank with a 4x15" laminated wheel. Looks like a sleeve may need to be put back in place?
   / Old rotary cutter, tail wheel assembly? #7
   / Old rotary cutter, tail wheel assembly? #9
You can likely find replacement bearings and bushings for the tail wheel center. If the yoke post and its housing is in decent shape, you might get another cutting season out of it.
   / Old rotary cutter, tail wheel assembly? #10
And buy a grease gun!
BOX BLADE (A58214)
BOX BLADE (A58214)
2011 SHOP MANIFOLD TRAILER (A58216)
2011 SHOP MANIFOLD...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
JOHN DEERE 469 BALER (A58216)
JOHN DEERE 469...
12ft x 8ft Military Flat Bed (A57453)
12ft x 8ft...
2015 MACK CXU613 (A58214)
2015 MACK CXU613...
