Bucket partially dumps when raising the loader...
   / Bucket partially dumps when raising the loader... #1
Pdiguy
Massey 245
Hoping to hear an easy fix before loading up for the dealer. The bucket has lost strength "scooping" up a heavy load. The bucket will half dump when raising the loader with a full bucket. Bucket is plenty strong dumping. All seals are clean and dry. My knowledge on this is very limited but an guessing the control valve may be bad? Any help would be really appreciated.
   / Bucket partially dumps when raising the loader... #2
Could also be the piston seals on the curl cylinders. If your tractor has quick disconnects in the hoses for curl lower the bucket to the ground. Unplug both hoses going to the curl cylinders. Now raise the loader and see if the bucket dumps. If yes the piston seals are leaking on one or both curl cylinders.
Note: this only works if the bucket dumps by extending the curl / dump cylinders
Thanks kindly for the reply. Put a good jag of gravel in the bucket, disconnected the 2 lines, raised the loader. Bucket didn't dump at all. I brought the loader back down, re connected the lines and the bucket half dumped when I raised it. Is it safe to say the lever/spool assembly is bad?
   / Bucket partially dumps when raising the loader... #4
You might check in the loader valve the load check, also check the can on the end of that spool.
   / Bucket partially dumps when raising the loader... #5
Pdi
Is the loader valve direct operated via joy stick or cable operated via remote joy stick? If cable operated they have been known to bind up and not allow the spool to spring center properly. If you can see the end of the spool where the linkage connects observe both spools to see if they appear to have similar travel and protrude a similar amount in spring center position.
Like lee john also look at other end of spools to see if the centering spring assembly has worked loose, is full of crud etc.
Nothing internal on the valve to rebuild to stop this drift. The load check that leejohn refers to will prevent dumping while trying to curl.
   / Bucket partially dumps when raising the loader... #6
Not sure what model tractor you have. Some have “spill” guard feature that levels or rotates the bucket level when raising. This prevent spilling back toward operator. Depending on model as they use different mechanisms to perform this feature. Bent actuator bars or mid-adjustment may cause your issues. Consult your owners manual.
My M59 even has a setting to keep pallet forks level moving up and down.
   / Bucket partially dumps when raising the loader... #7
If you have a cable operated joystick they can build up dirt inside the cable at the joystick end. This can cause things to not centre properly. Penetrating oil will fix it if that is your problem. Pulling back the rubber cover and holding it back and appling the penetrating oil is a 3 hand job.
Hopefully an easy fix like that is all you need.
Thanks for the reply. This might be a bit over my head. It's looking like a trip to the dealer is going to have to happen..
So here's what I'm working with. This dumping issue is something new so I don't think it's safety related. Maybe taking this unit to a local hydraulics shop will get me some answers. Or maybe it's just time for a replacement. The linkage on the levers are awful ovaled and sloppy anyways. Guess I'll see what the hydro shop says.
   / Bucket partially dumps when raising the loader... #10
I'd be surprised if the advice from the dealer's shop can match the expertise from the members here who have commented.
You now know for sure that the cylinders are good. So be wary if that it is suggested otherwise.
I don't know that particuar control valve or even the tractor. So can't help. I'd be surprised if it had regeneration or load leveling. It might not even have load checks. The less expensive control valves do leak internally and have none of those features.
Brand new control valves are available all over the internet. They are a universal part. The group here can help you specify a replacement. Prices run several hundred dollars and up...depending on quality. Dealers often charge much more for their identical control valves.
rScotty
Can-Am Defender 11000 (A59814)
Can-Am Defender...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
Topsoil Trommel (A57453)
Topsoil Trommel...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
1997 International F-9370 Eagle Log Truck, VIN # 2HSFBASTXVC083719 (A57453)
1997 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
