276d battery
/ 276d battery #1
Prof Elm
Yanmar 276d
I'm trying to find a battery that would fit a 276d, as N70Z batteries aren't commonly available.
/ 276d battery #2
Welcome to TBN.
Where are you located? NZ? It might help.
N70Z is an older battery size for lands down under, N70 would also work as it is a bit smaller than N70Z, or measure the battery that you have and use a BCI chart to find one close.
Here is a pretty long one, but I often find it more useful to use one from your local battery distributor/reseller.
All the best, Peter
/ 276d battery
Welcome to TBN.
All the best, Peter
In the us, that's what the tractor manual calls for. I will have to measure the battery and the tray and see what fits, I'm not at the tractor at the moment. I was hoping someone would know what would fit off-hand.
/ 276d battery #4
N70Z is equal to Battery Group 27. Now for the terminal type on top or sizes and the sizes, then the suffix letters are important to match.
Stats on a N70Z are,
Nominal Voltage: 12
CCA @(-18°C): 720
RC @ (25°C): 160
AH: 80
Length: 304
Width: 173
Height: 203
TH: 224
Wet Weight: 19.7
Assembly: D
Post Type: STD
Other Features: CV, FL, FDH, HE
Warranty: 30
Battery Type: Maintenance Free
Stats on a Group 27
  • Cold cranking amps: 810
  • Reserve capacity: 180 minutes
  • Voltage: 12
  • Terminal location: Top
  • 306L x 172W x 225H
/ 276d battery
Nominal Voltage: 12
CCA @(-18°C): 720
RC @ (25°C): 160
AH: 80
Length: 304
Width: 173
Height: 203
TH: 224
Wet Weight: 19.7
Assembly: D
Post Type: STD
Warranty: 30
Stats on a Group 27
  • Voltage: 12
Nominal Voltage: 12
CCA @(-18°C): 720
RC @ (25°C): 160
AH: 80
Length: 304
Width: 173
Height: 203
TH: 224
Wet Weight: 19.7
Assembly: D
Post Type: STD
Warranty: 30
Stats on a Group 27
  • Voltage: 12
This looked like it would work.
/ 276d battery #7
The Org. Alt. for a 276 is a Dyno so Tech not a true Alternator. Alternator - AL-1215 - Fredricks Equipment Parts
If you still using a Dyno it's only putting out 15 amp.. I look into that and then make a battery size choice.
I have always looked for the battery to have more CCA then the original equipment one had. Why would having a low output generator instead of a higher output alternator make a difference in the size of the battery chosen. The Farmall 560 originally had a small generator on it I'm thinking it was a 16 amp output and we always used the best CCA battery we could, it would just take a bit longer to fully charge the larger battery IF it gets discharged more then a smaller one would have.
/ 276d battery #8
I maxed my Battery out size wise that would fit in the tractor! I use a elcheapo Wally world 750CCA.. Cold start why! Which the Thermal start I never hardly use but the extra power is there when I needed it. No Dynahomo here.... Only replace the batter once since 2008 and it was a 550 CCA...
211453 (A62131)
211453 (A62131)
CASE IH 215 PUMA TRACTOR (A62130)
CASE IH 215 PUMA...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63118)
2023 Top Air ATV...
John Deere 1025R (A62177)
John Deere 1025R...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63118)
2008 Ford F-250...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
