276d battery
/ 276d battery #1
Prof Elm
Yanmar 276d
I'm trying to find a battery that would fit a 276d, as N70Z batteries aren't commonly available.
/ 276d battery #2
Welcome to TBN.
Where are you located? NZ? It might help.
N70Z is an older battery size for lands down under, N70 would also work as it is a bit smaller than N70Z, or measure the battery that you have and use a BCI chart to find one close.
Here is a pretty long one, but I often find it more useful to use one from your local battery distributor/reseller.
All the best, Peter
/ 276d battery
Welcome to TBN.
All the best, Peter
In the us, that's what the tractor manual calls for. I will have to measure the battery and the tray and see what fits, I'm not at the tractor at the moment. I was hoping someone would know what would fit off-hand.
/ 276d battery #4
N70Z is equal to Battery Group 27. Now for the terminal type on top or sizes and the sizes, then the suffix letters are important to match.
Stats on a N70Z are,
Nominal Voltage: 12
CCA @(-18°C): 720
RC @ (25°C): 160
AH: 80
Length: 304
Width: 173
Height: 203
TH: 224
Wet Weight: 19.7
Assembly: D
Post Type: STD
Other Features: CV, FL, FDH, HE
Warranty: 30
Battery Type: Maintenance Free
Stats on a Group 27
  • Cold cranking amps: 810
  • Reserve capacity: 180 minutes
  • Voltage: 12
  • Terminal location: Top
  • 306L x 172W x 225H
/ 276d battery
Nominal Voltage: 12
CCA @(-18°C): 720
RC @ (25°C): 160
AH: 80
Length: 304
Width: 173
Height: 203
TH: 224
Wet Weight: 19.7
Assembly: D
Post Type: STD
Warranty: 30
Stats on a Group 27
  • Voltage: 12
Nominal Voltage: 12
CCA @(-18°C): 720
RC @ (25°C): 160
AH: 80
Length: 304
Width: 173
Height: 203
TH: 224
Wet Weight: 19.7
Assembly: D
Post Type: STD
Warranty: 30
Stats on a Group 27
  • Voltage: 12
This looked like it would work.
/ 276d battery #7
The Org. Alt. for a 276 is a Dyno so Tech not a true Alternator. Alternator - AL-1215 - Fredricks Equipment Parts
If you still using a Dyno it's only putting out 15 amp.. I look into that and then make a battery size choice.
I have always looked for the battery to have more CCA then the original equipment one had. Why would having a low output generator instead of a higher output alternator make a difference in the size of the battery chosen. The Farmall 560 originally had a small generator on it I'm thinking it was a 16 amp output and we always used the best CCA battery we could, it would just take a bit longer to fully charge the larger battery IF it gets discharged more then a smaller one would have.
/ 276d battery #8
I maxed my Battery out size wise that would fit in the tractor! I use a elcheapo Wally world 750CCA.. Cold start why! Which the Thermal start I never hardly use but the extra power is there when I needed it. No Dynahomo here.... Only replace the batter once since 2008 and it was a 550 CCA...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2022 J&M TF212 Rolling Harrow (A63116)
2022 J&M TF212...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
