3 point auger help
/ 3 point auger help #1
I went to use my 3 point auger on my JD 4710 tractor for the first time in years.
Everything hooked up fine but when I drop the auger to the dirt it won't screw down to create the hole. The lift mechanism is totally dropped, it just wont dig in.
Any help would be appreciated.
/ 3 point auger help #2
Can you post a Photo of the tip of the auger? Is the pointy tip replaceable? Are we talking red clay dirt or rocky? (no location listed so just guessing).
Does your PHD have a way to slide a pipe in and add extra down pressure? Leinbach line like mine does... Again photo might help.
Try soaking the area with water to see if that helps....
/ 3 point auger help #3
Does the auger actually touch the ground, in other words has the three point hitch been adjusted not to lower far enough?
Thanks to all for responses. I'm enclosing a pic of cutter. Slight clay content in soil, otherwise sandy loam. I've tried uploading a video but can't get it to take. Bit spins, I've tried low speed, high speed. With bit tucked up under auger arm 3 point arms allow for full descent.
/ 3 point auger help #7
I have sandy loam over clay. When it gets hot & dry the ground gets like concrete.
As Old & Tired suggested, try soaking the area with water. If/when the bit actually digs in, let it run
for awhile, pull up slightly to eject dirt from bit BUT do not raise the bit completely out of the hole.
Keep repeating until desired depth or bit limit is reached. Good luck.
/ 3 point auger help #9
I picked up one of these (really not sure where I put it) I was planning to weld on the support "wings" but really never needed the post hole digger much after buying it. This is 1-7/8" there is another that's 2" shank... wonder if it would help.
/ 3 point auger help #10
Yep, that pointy spike on the end won't dig too well......
This auger from TSC will dig to China! 4 cutting edges, and the spiral tip.
I have very hard sandy loam / clay. These are very good for the price, plus the tips are all replaceable.
/ 3 point auger help #11
As @LS Tractor Owner states, that tip is the problem. I have never seen an auger tip like that.
If you must use that particular auger you could try hand digging a small hole that would allow the cutting edges to get a better initial bite.
/ 3 point auger help #12
With mine when the soil is too dry on clay soil with thick vegetation I need to add weight to it in order for it to start digging.
/ 3 point auger help #13
I’ve seen and used two augers with tips like that. When the ground is soft they work, but they are not a desirable auger.
The only thing is that is the only type of tip that will work on that auger. To switch to the screw tip you need to buy a different auger.
