Just another junk chainsaw
   / Just another junk chainsaw
All the 490 needed to stop fines from getting by. So all the 501 is getting too. 272 o-ring fix Corey found to work on his 4910 way back.
Psi check. Good like it felt.
Like standard cover 501 over the spring assist on 490.
But understand why some folks need those.
Love the feel of the rubber grip metal handle over the plastic handle big time.
Just so you guys know thats on a budget and want a light 25cc clone of echo 2511.
Their out since last year and in states now. 149-159 gets you one it seems.
Weigh 2 ounces more then oem, so like 5lbs 6oz I think PHO dry. Have 2 bar studs instead of one. Carb venturi measures smaller. Few folks in my chainsaw repair group tearing into them to see. Also the 1/4" mini chain bar set ups with drum can be had for 50 more for them.
Just thought some might find it interesting too.
Pic in middle of one getting checked out by a guy that ports them.
Forgot this. One of the caps were smaller too.
   / Just another junk chainsaw #1,764
Yeah but then you're just supporting China and their corporate theft...
   / Just another junk chainsaw #1,766
The Echo brand of hand-held petrol powered tools including chainsaws, brushcutters, hedge trimmers and leaf blowers are manufactured in Yokosuka and Morioka, with other major plants in Shenzhen, China and Lake Zurich, Illinois.
   / Just another junk chainsaw #1,767
All OEM are in China and invested millions into their country for 15 plus years now. How do you think all this stuff is coming out of there.
Stihl Husky Makita Echo etc etc etc. STIHL in China: Production sites in Qingdao, Huizhou and Hong Kong | STIHL
So dont buy it. Your choice. It's that simple.
But 90% of the stuff you buy everyday is from there. ;)
What I am saying is that when they clone these saws, they are stealing the designs and then producing them. Would YOU want to spend YOUR hard earned money and time designing something that you hoped to profit from, and then have your neighbor steal all that work from you and start profiting from it?
But you are right, it is my choice not to buy it or support it. And I won't.
Was dealing with roof repair for 2 days. So today I can get back into the saws.
Got the deflector on echo 501 to where I wanted it.
My whole reason for what I am doing is trying to keep the hot exhaust from blowing out the sides and melting brake handle.
Just using the oem deflector again 4910 501 490.
Just like 590 620 there is no reason for those pricey aftermarket cnc ones unless just being to lazy to do yourself.
This saw is easiest dang saw to start. 1 pull cold pops and 2 afterwords.
No clue why decomp as never used it on this. Maybe for folks with shoulder issues or once ported.
   / Just another junk chainsaw #1,769
Echo is real good at mounting their exhaust deflectors pointed at something that can melt for some odd reason. I made that deflector adjustment on both my CS top handle Arborist saw and my Timber Wolf. The TW requires removing the muff, unscrewing the top baffle /deflector plate and the spark screen and then taking a die grinder and removing the spot welds so you can rotate the deflector to a better position where it's not blowing hot exhaust gasses on the plastic. Same with the CS other than it's not spot welded to the muff at all. Pizz poor design on the part of Echo on both saws. Of course on the Wolf, I did the Red Beard foam air cleaner (described my issues on the Arborist Forum, did the offset flywheel key, removed and modded the limiter caps, and the muff as well. I left the stock ignition coil and rev limited in place however but I may change that in the future, not sure. The saw will do a full bar cut (20" bar) ripping dried oak logs with a sharp loop of course, but then I always have sharp loops anyway and the rakers set to 0.025, no issue and modding the muff , it sounds like a MX bike now.
   / Just another junk chainsaw #1,770
Glad to see you finally calling the Timberwolf buy it's proper name. :ROFLMAO: This is a very easy saw to modify and it really opens it up. You should adjust the squish on it a little, it really helps it out even more...
   / Just another junk chainsaw #1,771
I agree, buying something that was simply made in China is one thing. Buying a knock-off copied by China and made in China is completely different. The first is bad, but understandable. The second is horrible for people here to buy.
   / Just another junk chainsaw #1,772
Yes, it's terrible. These companies spend millions on design, engineering, testing, patents, and production to produce a nice product. Then out of control China swoops in and illegally steals that design and starts producing and selling these products for a fraction of the cost because they invested NOTHING into it. And it's not just happening to chainsaws but across the entire board from saws, to TV's, to imitation purses, etc... And the people who buys this crap, SUPPORTS it.....
   / Just another junk chainsaw #1,773
Bear, Wolf, all the same (and I should know as it's stenciled on the bar as well). Not wanting to open the jug up unless it develops an issue, then I will. Runs peachy with just the Red Beard oiled foam air cleaner, the modded muff and the offset timing key and pulling the limiter caps and snipping off the limiter tangs and then reinstalling them. I did post an error on the CS saw. I bought a replacement muff from Saw it Again. The replacement muff is actually an Echo factory muff with the guts and cat ring absent and the final diffuser / deflector is on a bit different so the exhaust isn't directed towards the outer plastic cover. On the CS saws, the number one complaint (on Echo's website) is the muff deflector melts the plastic outer case.
   / Just another junk chainsaw #1,774
Guess that pretty much eliminates DeWalt and Milwaukee Li-Ion battery powered hand tools then as they are made in Chinese or Taiwanese factories. Might as well by HF Bauer or Hercules battery powered tools for a lot less cost the, They are made in those very same factories but sold at a much less cost.
Just replaced the 2 batteries in my wife's Suburban and purchased 2 Delco AGM batteries from Walmart and guess where they were made, only one guess and the country's name begins with a 'C'. I could hardly believe it. Thinking about it, they will probably last longer than the Delco's they replaced because the old batteries weren't made in China but here.
Of course with the rapidly increasing cost of shipping containers (over 10 grand today with surety insurance, the Chinese goods are rapidly loosing their value as a cheap alternative. You can thank the Houlti's for that, that and the fact that container ships now have to travel around the Cape of Africa which adds an additional 3 days to each voyage as well as the extra bunker diesel required to make the trip..... and the summer storms there are wreaking havoc on the ships themselves. The cost to ship voia container has went up appreciably since the Houlti's started firing their rockets and unmanned small ships loaded with explosives and hitting ships trying to use the Suez canal is contributing to the overall cost of shipping cheap (not so cheap anymore) Chinese goods here. Until the US and other nations just level Yemen and eliminate them, the cost will continue to go up on all imported stuff from not only China and Taiwan but from India as well as Japan. It all comes here via overseas containers. Diplomacy ain't working with them at all. It all started with Israeli owned ships or ships headed to ****** to offload, but now they are shooting at everything and anything.
   / Just another junk chainsaw #1,775
You don't seem to be getting my point. Jeephead explains it better than I did, so maybe read his posts. Let's say you spend 10 years designing and perfecting a "5030 Hand Tool" which is better than any hand tool out there by far. You have it made in China to keep costs down and sell each "5030 hand Tool" at $100 each. Other Chinese companies hear of your fantastic "5030 Hand Tool" and visit the Chinese you have building it. They take one of your "5030 Hand Tools", reverse engineer it and sell a "5031 Hand Tool" for $50 at HF since they have zero invested perfecting the tool. Your same color, your same look, your same design. You suddenly are out of business, 10 years' worth of time invested down the drain since you never broke even. I don't like buying stuff made in China, but sometimes I have to since there often is no choice. I NEVER buy knock offs, however. I'd rather pay $100 for the original "5030 Hand Tool" so you can stay in business and recoup your investment.
We been buying cloned stuff for as long as I can remember back.
Go to the car part store. Your buying cloned China made parts with whatever name on it.
Go buy a motor for that mower or splitter or kart your usually getting a Honda cloned motor.
Name brand tools cloned, Chain grinders, etc etc etc.
Atv's and dirt bikes cloned.
You folks act like this just happened with chainsaws. Been going on as long as I can remember.
You are way late to the cloning game to be complaining now.
Oh good morning. ✌️ 😁
   / Just another junk chainsaw #1,777
I don't buy any of those off-brand alternatives, I buy the real deal. My ATV is a Honda, my saws are Husqvarna, Stihl, Echo, Dolmar. My engines on my power washers are a Honda, my cordless tools are Dewalt. I am not buying anything that is from stolen designs! I refuse to support this behavior or these products. And nobody is acting like anything just happened. We are highlighting that it IS happening and that it IS WRONG.
This isn't about buying a Chinese product, it's about buying products originating from stolen designs. There is a difference.
To each their own. You can't force people to do the right thing. It's either in you, or it isn't.
So you go to your OEM dealer to buy your OEM parts for your car, truck and tractor?
If your not, your buying cloned parts.
Just saying folks been doing it for many many years. Cant just pick and choose which your going to stand ground on.
   / Just another junk chainsaw #1,779
For the most part, yes, I buy OEM parts or high-end aftermarket parts. I am not foolish enough to say that I never mistakenly buy a cloned part....
High end aftermarket = cloned China parts. Just saying.
I'm not paying $600 for my alternator for car, truck etc at OEM. When I can go buy it for $100.
That is my point we all do it and you cant just pick what ground your going to stand firm on.
Deere 410L (A53317)
Deere 410L (A53317)
iDrive TDS-2010H...
2022 New Holland C327 Compact Track Loader (A61306)
2022 New Holland...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2012 Dodge Avenger Sedan (A59231)
2012 Dodge Avenger...
