Bringing Battery Back to Life?
/ Bringing Battery Back to Life? #1
LittleBittyBigJohn
Central Arkansas
John Deere 1025R, Kubota ZD1211
Is there any way to bring a normal led acid battery back to life that just won't keep a charge? I have my brother-in-law's excavator at my house and it is in need of batteries. I have filled them with water and charged them. They will start it just fine soon after they are charged and they test good, but they will not hold a charge more than a week or so. I don't really want to have to put $400 worth of batteries in it if I can help it.
/ Bringing Battery Back to Life? #2
Are you sure it is a bad battery versus a constant drain on the battery when the unit is off? Try disconnecting the battery cable after use once and leave it off until you need to use it again. If it fires up OK when you reconnect the cable there is a drain. If not, it is the batteries going bad. If the former, consider a master off electrical switch to use when unit is not in use.
/ Bringing Battery Back to Life? #3
Check the battery voltage before use and then again while the machine is running. The voltage should be higher when the machine is running, indicating the charging system is working.
Then disconnect the battery when done using the machine and see if they hold their charge by checking the voltage in 24-48 hrs.
/ Bringing Battery Back to Life? #4
Recent had to replace battery on generator, it had a battery tender connected to it, and voltage always tested good but when loaded (start button pushed) it went down to about 2 volts and only would spin generator about 2 revolutions and with generator running there was sufficient change voltage of about 13.7 volts..... Yes it was bad had no "capacity".... Put voltmeter across battery's (24 volt) and if it drops more the 3-4 volt cranking batteries have no capacity... Beside it is borrowed, fix problem before returning, so its $400, how much money did you save by not hiring out the work....
/ Bringing Battery Back to Life? #5
Always check voltage under load, its the real telltale sign of batter capacity, it should not drop more than 7-10% when cranking...
/ Bringing Battery Back to Life? #6
You say they test good after charging. Please describe your testing. If you are just putting a voltmeter on the battery at rest, that's not much of a test. Get or borrow a load tester and see what that says.
If you've got a bad cell, the voltage will usually drop down to 10.5 volts or so over several days (even if battery is disconnected from any loads). If you do have a bad cell, it's time for a new battery.
If it's not a bad cell, you might try charging with a battery charger that has a desulfation feature. Lead-acid batteries that sit in a state of partial discharge for an extended period experience sulfation, which slowly kills the battery. Sometimes a charger with a desulfation feature can bring these batteries back. It can take some time to recover them. (I recovered a couple that took a week on the desulfating charger to become usable again.)
/ Bringing Battery Back to Life? #7
You could take both batteries to an auto parts store and have them test "under load"..... and it's free!
They can also use a heavy duty charger which will de-sulfate it also.
That's the only way to tell if a battery is bad--- needs a load
/ Bringing Battery Back to Life? #8
As said before, you need to test battery at 50% of cold cranking amp rating for 20 seconds or so. I use a carbon pyle tester for this.
I do generator maintenance as a retirement project. I take care of aprox 300 generators. When i find a battery that doesnt pass this basic test, i swap it out. Ill alert the owner first. If they dont want it done, i tell them not to call me when unit doesnt start.
This has stopped my power out calls for repairs.
I also use a Midtronics electronic tester to verify that there are no damaged cells.
Just testing voltage is useless on batteries.
/ Bringing Battery Back to Life? #9
They are almost perfectly designed to last 5-7 years. Just buy a new one.
/ Bringing Battery Back to Life? #10
I have master disconnects on both my Kubota M9 tractors and I use them every time I park them. They are on the NEGATIVE terminals not the positive terminals and you can buy them pretty cheap at any AP store or off Amazon.
NEVER top off any wet cell battery with tap water or well water or rain water. Always use DISTILLED water. Ordinary water has minerals in it that will degrade any wet cell battery and...
I change out my starting batteries in my tractors every 5 years no matter what. Wet cell batteries all degrade over time and will fail at the most inconvenient times and contrary to popular opinion, wet cell batteries will fail in hot weather more than cold weather.
Finally, keep the battery posts and clamps and the connections where they attach to the starter clean and bright and use a oxidation preventer on the posts and clamps and make sure they are tight and the leads not corroded or frayed. I use Fluid Film on my battery posts and clamps. HF sells a dandy post and clamp cleaner brush for under 5 bucks every day, get one and use it.
/ Bringing Battery Back to Life? #12
I handed them to the guy at O'Reilly and asked him to test them.
OK. I'm assuming that included a load test.
It's still possible the batteries are sulfated, which would increase the rate of self discharge even with no load on the battery. There are some good desulfating charger/maintainers that are not very expensive. I own several various models of BatteryMINDer brand charger/maintainers and have been very happy with them. I like them because the desulfation circuit remains active even after the battery is charged, so they will continue to work on a sulfated battery even after it has reached it's target voltage. On the less expensive end of their product line, check out the model 1510 or the more weatherproof 1215C. These are 1.5 amp charger-maintainer-desulfators. On the more deluxe end of their scale, look at the model 128CEC2 - it's selectable 2/4/8 amp, with a selection of charging profiles for various battery types and some diagnostic abilities. (Noco chargers and maintainers are also very good, but their desulfation circuit is only active when the battery is actively charging, not when it is in "float" or maintenance mode. For a heavily sulfated battery, you may have to run through a number of cycles to recover it.) Both brands are safe to leave connected to the battery for long periods. They will not overcharge or damage the battery.
The other possibility could be a drain in the battery even when things are turned off. Worth checking for some phantom load from the equipment. Also, if the battery is very dirty, various dirt/oils/water/acid on the battery case can form a conductive path which slowly drains the battery. A good cleaning might help. (Some like to neutralize any acid in the much that is coating the battery by wiping it down with a solution of baking soda and water. If you do this, be VERY careful around the battery cap: you definitely do NOT want to get any inside the battery.)
(APPROX. 5) 28' - 29GA BLK TIN (A63290)
(APPROX. 5) 28' -...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
(5) JOHN DEERE WEIGHTS (A63290)
(5) JOHN DEERE...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2011 GREAT DANE 7211TZ 53FT T/A REFRIGERATED TRAILER (A59910)
2011 GREAT DANE...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
