Grill guards
/ Grill guards #21
Just ordered one from homestead. I was moving brush for a neighbor with the grapple on my BX and quickly realized the openings in the grapple could easily allow a branch to get my radiator thus the order as I don’t weld a skill I never learned
/ Grill guards #22
Do you guys have protection from underneath? I put two layers on the front, bottom section and I did not cover my head lights (if I can't see brush that high, I don't need to be where I'm at).
/ Grill guards
Thanks 2515R Dude. The more info - the better.
/ Grill guards
I just finished a project where the grill guard came into play. I disassembled - gathered - moved the last old homestead building.
I can certainly see why HD industrial equipment would have been better. But you use what you have.
The grill guard got thumped/bumped several times with the old lumber.
Now I have to clear this area of all the remaining nails/spikes. There was not a nail/spike that the old homesteader didn't like. With my metal detector I've gathered up two gallon buckets full.
I can guarantee - I've not found them all yet.
/ Grill guards
My expanded metal wraps up underneath - old and tired. But then - I don't go crashing thru the undergrowth like Gordon Gould - #6.
My property is open fields of grass and stands of ancient Ponderosa pines.
What "under growth" I have - Buck brush. Diameter of a pencil and two feet high. Driving thru this brush just tickles the underside of the tractor.
/ Grill guards
WranglerX - that particular guard is at - 5elevendesignz.com.
/ Grill guards #30
JD 2520 grill guard upgrade. A little 3/8" rod and 1/8×1" strip stock. A few close calls on the grill drove the change.
/ Grill guards
dadohead - that is a great guard. Some of us, me included, just don't have the imagination nor skill set. Fortunately - I have a welding shop local.
/ Grill guards #32
That's very kind of you... but I do what every other designer does: steal good design and use it in my application! If you see something you like... heist it!
/ Grill guards #33
My brush guard and chain holder. Two 5/16" gr70 10' long.
/ Grill guards #36
I had a local fabricator friend make this for me. It was from stock he had lying around left over form another project. I'm thinking he must have been watching some of the Mad Max movies before he made it.
/ Grill guards
WoW - John. Your friend went all the way for you. Mad Max - yes. Those two upper tubes go all the way back to the roll bar - ??
/ Grill guards #38
Yes, the two upper tubes are "limb risers" - they push the limbs up and over, rather than slapping me in the face. Once I got them, I know I'll never have a tractor used in the woods without them.
/ Grill guards
I get "limb slap" plus a lap full of snow when I plow my driveway. The young pines bend in onto the driveway from the weight of the snow.
Once or twice can be refreshing. But a mile of it going in and again going out. Gets to be a little much. I can eliminate most by raising and opening the grapple.
2007 Acura TSX Sedan (A61569)
2007 Acura TSX...
2008 Land Rover LR3 AWD SUV (A61569)
2008 Land Rover...
APPROX. 12'X25' GOAT PEN (A62131)
APPROX. 12'X25'...
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
February 26 2026 (A64047)
February 26 2026...
UNUSED SDLANCH 12' X 20' METAL LIVESTOCK SHED (A62131)
UNUSED SDLANCH 12'...
