My new Massey Fergusson 4707 is here!!!!
/ My new Massey Fergusson 4707 is here!!!! #62
listening to you, one would think curing concrete never stops indefinitely.
Correct and it can and will cure underwater.
/ My new Massey Fergusson 4707 is here!!!! #63
As long as it is wet, concrete will continue to increase in strength for at least a year. Water allows the hydration and carbonation chemistry to proceed, trapping CO2 and some water in the concrete, as @DarkBlack posted, but over time much of the water does evaporate. Some kinds of concrete, e.g. Roman concrete will self heal and continue to cure thousands of years later.
Which is what a good concrete contractor will do in my opinion!
(Just to head off any flames, if someone believes otherwise, please go read up on concrete curing at the Portland Cement institute, or any of the many, many papers published on concrete curing and strength. Accepted local practice is not the same as good practice.)
There may be scheduling reasons not to keep concrete wet, but ultimate strength, longevity, or resistance to cracking are reasons to keep it wet.
Concrete pours should stay wet for at least a week or longer for building strength, and reducing shrinkage. That means wetted down, covered with burlap/rugs/cardboard, plastic, with enough water to keep puddles going. For any given pour, there is less shrinkage and the ultimate cured strength is higher.
All the best,
Peter
/ My new Massey Fergusson 4707 is here!!!! #64
Perfect Eddie . . . really nice!
/ My new Massey Fergusson 4707 is here!!!! #65
On bridge projects, we kept concrete wet for 28 days. At that point, the concrete had reached 90% of its design strength. When we shut off the water, we sprayed it with a concrete curing membrane to keep the surface from drying out.
Generac 5000W Heavy Duty Portable Diesel Generator (A59317)
Generac 5000W...
GUIGONG CLG9035E EXCAVATOR (A62129)
GUIGONG CLG9035E...
CFG Industrial 680 QA Hydraulic Hummer (A60463)
CFG Industrial 680...
Sellick S80 (A60462)
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
Cutter (A59317)
Cutter (A59317)
