My new Massey Fergusson 4707 is here!!!!
/ My new Massey Fergusson 4707 is here!!!!
I used exactly 25 sacks of concrete that weigh 60 pounds each. The metal frame was just over 100 pounds. 25x60+100=1,600
/ My new Massey Fergusson 4707 is here!!!! #53
If those were 60lbs dry, there's also the weight of the water that is incorporated into the finished concrete.
How much water weight is added to a sack after it's cured?
/ My new Massey Fergusson 4707 is here!!!! #56
Exactly!
Water has physical properties; Frozen, vapor, liquid...all of which are not present in dried concrete.
We can't get around physics and the only thing present in dried concrete is still Portland, limestone and aggregate. Water was just the ingredient that prompted the chemical reaction and then it's evaporated off as it's no longer needed.
A cement truck is limited to 10 yards due to weight. However a dump truck can haul off more than 10 yards of dried concrete. :cool:
/ My new Massey Fergusson 4707 is here!!!! #57
Sure about that?
Concrete is cured, not dried.
I believe a good majority of the oxygen, and hydrogen of water mass is chemically bonded in the Portland cement in the chemical curing process
/ My new Massey Fergusson 4707 is here!!!! #58
Sure about that?
Are you sure?
Curing is a temporary process where as dried is when the hydration process is complete.
Bring a better semantical game...
/ My new Massey Fergusson 4707 is here!!!! #59
Are you sure?
I’m no chemist, but..
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
Peterbilt 377 Semi-Truck (A61307)
Peterbilt 377...
2021 Bobcat T66 (A60462)
2021 Bobcat T66...
2006 INTERNATIONAL L9227(INOPERABLE) (A60736)
2006 INTERNATIONAL...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
