Translating PA's towing limits - can I tow a 15,000 pound trailer?
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I'm trying to determine if I can legally tow a trailer in PA. This is the document that I am apparently not smart enough to parse. https://www.dot.state.pa.us/public/DVSPubsForms/BDL/BDL Fact Sheets/FS-NCAB.pdf
I have a 2016 Silverado 3500 SRW. The trailer that I'd be towing has weight rating of 15,000 pounds. The maximum combined weight rating for a normal drivers license in PA is 26,001. So, what's the actual data to use? Is it the GVWR of my truck (where do I get that exact number? Didn't see it on any stickers in door jam or glove compartment) + 15,000 weight rating of trailer? So, if the GVWR of my truck is 10,000, I'm good, because it'd be 10,000 + 15,000?
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #2
What a confusing document. But one of the examples says you need a class A to tow an empty trailer with a GVWR over 10k lbs. That's pretty straight forward and probably not what you wanted to hear.
I think that with a 3500 and a 15k GVWR trailer, you're likely to also be over the combined 26k GVWR because the truck's probably over 11k. I'm surprised that either the GVWR or payload + curb weight is not on a door sticker somewhere.
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #3
You don’t need a CDL unless your truck has a GVWR of over 11,000. Look on your door jamb sticker again. I bet the GVWR is on there.
If it’s over 11K, you need a CDL.
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #4
This type question which comes up about once a month proves how poorly written the regulations are.
Bruce
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #5
The PA laws and CDL laws in general are desperate need of re-writing. Trucks, their safety, brakes, suspensions, etc. are so much improved from when those laws were written-probably in the 80’s.
Thanks y'all. Sounds like it's:
  • If combined weight < 26,001 and trailer weight > 10,000, Class A CDL
I suspect I won't be able to get a class A CDL by Saturday. Oops.
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #7
De rate your trailer until both are under 26
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #8
If you’re not doing it to earn, get a non-cdl which Pa does offer. Less hassle
Classes of Driver's Licenses​
Non-commercial Driver's Licenses​
  • CLASS A (minimum age 18): Required to operate any combination of vehicles with a gross weight rating of 26,001 pounds or more, where the vehicle(s) being towed is/are in excess of 10,000 pounds. Example: Recreational Vehicle, when the towing vehicle is rated at 11,000 pounds and the vehicle towed is rated at 15,500 pounds (total combination weight of 26,500 pounds).
  • CLASS B (minimum age 18): Required to operate any single vehicle rated in excess of 26,000 pounds. Example: Motor homes rated at 26,001 pounds or more.
/ Translating PA's towing limits - can I tow a 15,000 pound trailer? #9
I don't interpret it that way. To me it looks like If combined weight >26,001 and trailer >10,000 Class A CDL. Everybody likes to focus on the trailer over 10K but miss the qualifier that the entire combined weight has to exceed 26,001.
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
We do NOT accept credit cards as payment. (A60462)
We do NOT accept...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
