Rear 3PH is not working - running into a wall
/ Rear 3PH is not working - running into a wall #1
arcteryx
Texas
JD 3032E w/ Loader
Short- Recently got a 2010 3032E, but I know this is very similar if not the same hydraulics as the 3038E. The FEL and power steering work as it should. Rear 3PH does not move. I don’t know if they worked before or not. I do have the tech service manual
Long- I rebuilt the lift cylinders as they were leaking. I also replaced several hydraulic hoses due to age. And I drained/filled the hydraulic fluid and replaced all filters, including the 2 hydraulic filters on the left side under the seat/food area. So the system was open for air to enter. Still not working, so I removed the hydraulic manifold/control valve. I ended up disassembling the control valve and put new o rings in it.
For the manifold, I blew some air through it but it did not see like I was getting the proper output on all ports. Unless there is a procedure for bleeding, I will remove the manifold again.
Questions-
1- I am wondering if air is trapped in the rear. Is there a way to bleed the hydraulic system?
2- Is there a diagram of the manifold flow or how to tear it down? I cannot find one on the parts diagram or in the service manual, at least that I can find.
3- I suppose it could be the o rings on the piston, but I would expect it to move a bit even at higher RPMs
/ Rear 3PH is not working - running into a wall #2
Should not have to bleed the system.
Look elsewhere for the problem.
/ Rear 3PH is not working - running into a wall #3
Is the FEL valve factory installed or an add on after market?
How many lines connect to the FEL valve including the four for the loader functions?
As a temporary test with no load on the three point. Lower the 3 point fully then move lever to raise while simultaneously raising the loader. Does 3 point raise then? If yes then suspect tank and power beyond hoses on the FEL are swapped but you need to trace the lines to confirm this.
Like been there states no reason to bleed a pressure line in this circuit it will self bleed the air.
/ Rear 3PH is not working - running into a wall #4
Do you have an adjustment knob that controls the speed of up/down? Sometimes if those are set wrong, they won't let the 3pt move.
It is OEM and came with the tractor from the factory.
I tried the temporary test and there was no change.
Yes, it controls the down. I have tried multiple ways and still nothing.
/ Rear 3PH is not working - running into a wall #6
Arcteryx
How many lines are connected to the FEL valve? I presume seven. Since 3 point does not work it becomes more challenging to diagnose without a flowmeter since you need to determine where the flow is going. A possible option to check FEL valve power beyond circuit would be to install a flow control and gauge in the power beyond line. Slowly close the flow control with FEL controls all in neutral position. If pressure begins to rise and continues to relief pressure then problem is most likely in the three point valve. If pressure does not build
then problem is in FEL valve power beyond circuit.
NOTE: be a 110% certain you working with power beyond line and not tank line if doing above test.
/ Rear 3PH is not working - running into a wall #7
#pt lift has it's own pressure relief valve. Could be stuck open or the o-ring is torn and leaking.
Thanks for the replies. I will look tomorrow and count the lines and report back.
I did remove the manifold again as well as the control valve. I did not tear down the control valve but did do it to the manifold. I remove all of the valves to ensure they were not stuck. Reinstalled everything and still no working 3PH. I am at a loss.
I have 7 connections, 6 on the bottom and 1 on the side.
/ Rear 3PH is not working - running into a wall #10
Are any of the connections marked on the valve? Seems like there is no standard in how that power beyond port is labeled though. In most cases it is on the opposite end from pressure but again not always. This should go back and supply oil to the 3 point valve and rear remote valves if you have them.
Some valves have a “special” fitting sometimes called a sleeve that goes into valve to create power beyond others just have an internal plug. If the fitting or sleeve style it will usually have a taller hex than a standard fitting.
/ Rear 3PH is not working - running into a wall #11
I had this issue, turns out it was the third-function valve, the switch was defective causing the valve to be open all the time. The third function was "robbing" all of the hydraulic pressure from the 3-pt. The mechanic knew exactly what the issue was when I described the symptoms. Replaced the switch and everything works as expected.
/ Rear 3PH is not working - running into a wall #12
/ Rear 3PH is not working - running into a wall #13
Regardless of brand, the open center hydraulic system is used by most manufacturers. All of these open center tractor hydraulics work about the same. That's good, it makes diagnosing them easier.
They do not need to be bled, and there is no special provision for doing so. The sump (return tank) is open to the atmosphere and the hydraulic system is self-bleeding.
Since the power steering and FEL work, there should be pressure at the power beyond port on the control valve manifold. My first guess is that the "sleeve" that OldnSlo mentions in post #10 slipped out and was lost. The purpose of the sleeve is that it blocks extra flow from going to the return post and instead directs it to the power beyond port.
So those sleeves are always there - they have to be there - when power beyond the FEL manifold is used. You may want to take off the hose to that port and make sure the sleeve is stiil there. Sometimes the sleeve screws in, other ones just press in.
On it's way from the PB port to the 3pt and rear BH remotes (if there are any), the fluid goes past a solenoid for 3rd function accessories (front remotes), just as CaptPat says in post #11.
I would sure check that solenoid as well. It is capable of robbing all the flow. Normally, that solenoid will not have any flow diveted to it's return line to the sump.
A simple pressure test kit makes testing all of this easy. Inexpensive. Amazon and others have them.
rScotty
I will have to clean the FEL valve and see. Here are my connections though, there is one on the side that is not shown. None are a quick connect that I can tell. I labeled 1 and 2 when I replaced the hoses for the FEL.
Assuming you mean rear remotes, I don’t have a third-function.
Thanks for this. Where is this sleeve? Is this on the manifold or on the control valve (#21 below), which requires disconnecting the lines and removing the manifold. And to complicate things, the parts diagrams do not have a breakdown of the control valve but the manual does. I am guessing that they replace the control valve entirely and not the valves n bits themselves.
Here is the parts diagram I was able to get. They don’t make it easy to copy/paste links.
And what would be my PB port? Would it be labeled?
/ Rear 3PH is not working - running into a wall #17
What does the line with the blue zip tie connect too? It is the line in picture 5282 with the long hex fitting two connections above hose labeled 1. That style of talk hex is sometimes an indicator that it is a power beyond sleeve. I can’t tell if line next to it has same style fitting or not.
/ Rear 3PH is not working - running into a wall #18
The 3-pt is last in line to receive hydraulic press/flow, if anything before that is loading the system the 3-pt may not work. In my case, the 3rd-function valve was the culprit, either flow to the 3-pt is blocked/bypassed or something else is consuming hydraulic service. Since you have the tech man I'd trace the various hydraulic lines to verify proper installation, it's easy enough do and would rule out actions by a previous owner/maintainer. It may also be worth teeing a pressure gauge to verify that your pump is putting out rated pressure and flow.
OK here are the lines and where they go. Which of these would be the PB port? - EDIT- I don’t have PB
The blue zip tie is a loader hose up front.
The 2 metal lines underneath go to the 2 ports close to each other on the manifold.
The hose on the side of the FEL valve goes to the port at the bottom of the transaxle.
On the manifold, the one on the lower right bottom goes to the transmission. This is Item H on the hydraulic oil line schematic.
There are 2 smaller lines on top of the manifold as the photos show. The one on the left side goes to the piston under the seat, the one on the right side appears to be a return line and enter the top of the transmission/transaxle.
Lastly, here are 2 schematics from the my Deere manual. I don’t have a Bleeder Valve (G), although here is a hex cap. And where H would be on here, there is not a side quick connect
Hope this helps
/ Rear 3PH is not working - running into a wall #20
Page 70-30 -2 shows item H as implement pump to rock shaft valve supply so if my interpretation is correct line H would be connected to power beyond line from FEL to rock shaft valve which is 3 point hitch.
This is based on that diagram on page 70-30-2 not including an FEL valve.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
IR IRET13 ELECTRIC TRICYCLE (A62130)
IR IRET13 ELECTRIC...
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
2015 Land Pride RCM5615 (A60462)
2015 Land Pride...
2012 Volvo BL70B (A60462)
2012 Volvo BL70B...
2013 HERCULES ALUMINUM KILL TRAILER (A60736)
2013 HERCULES...
